Welcome to Chrysler, Dodge, Jeep, Plymouth, and related cars and trucks
Welcome to the Allpar forums for Dodge, Chrysler, Jeep, Plymouth, and other Mopar owners! You must register to post, but this is a simple, free process. Register now or sign in!
2000 Durango SLT 5.9 full accel problem
#1
Posted January 7, 2012 at 11:28 pm
Its like i'm turning the key on and off once per second (but it does not actually shut off)
Light to medium acceleration ok.
No codes.
#2
Posted January 8, 2012 at 05:33 am
A failing crank sensor or worn distributor may have a difficult time at higher engine speeds.
#3
Posted January 12, 2012 at 03:17 am
#4
Posted January 12, 2012 at 04:30 am
Does it happen over 4000 rpms even if you back off the throttle slightly?
Or can it occur from a stop if you mash the accelerator pedal?
There is little engine load when revving in neutral and it probably isn't a valid test of anything.
#5
Posted January 18, 2012 at 03:38 am
If I "floor it" from a stop it does not happen.
If I floor it from around 35mph, not sure of the rpm range and above it happens.
Normally noticed when trying to accelerate on freeway, or when tring to pass someone.
If I floor it and then back off a little it stops happening.
Home · Cars · Engines · Repairs · People Car Reviews · News · |
hello
