Welcome to Chrysler, Dodge, Jeep, Plymouth, and related cars and trucks
Welcome to the Allpar forums for Dodge, Chrysler, Jeep, Plymouth, and other Mopar owners!  You must register to post, but this is a simple, free process.
Register now or sign in!
  • Use the collective Mopar knowledge of the community
  • Post, reply, and subscribe to topics
  • Make new friends
  • Join us at our annual meets
Guest Message by DevFuse
2001 300M - Starting Problem
300M 125k
5 replies to this topic
#1 Mred
Mred
    Part of the Community
  • PipPip
  • 63 posts
Posted February 2, 2012 at 05:53 am
I have a 2001 300M which is exhibiting some starting problems.  It might not start with first key try, but then starts on next try.  I removed the battery and checked it - it was good.  Also made sure to clean the connections and put it back, but didn't fix the problem.  Does someone have experience with this on your 300M?  Might be a relay, hope not a starter, but not sure at this point
thx
#2 DaveAdmin
DaveAdmin
    Administrator
  • Supermen
  • PipPipPipPipPipPipPip
  • 13,858 posts
Posted February 2, 2012 at 09:10 am
Did you check codes? Is it only since you refilled the tank? Check the spark plugs?
#3 Mred
Mred
  • PipPip
  • 63 posts
Posted February 4, 2012 at 04:55 pm
No codes.  This is purely a connection issue.  The first key try does not result in starter actuation. As noted, this is either a relay or potentially a bad spot on the starter.  However, not sure.
What do you mean by refilling the tank?
#4 ImperialCrown
ImperialCrown
    Lives Here
  • Supporters
  • 7,607 posts
Posted February 4, 2012 at 05:21 pm
Do you just get a 'click' or nothing?
Do the dash or headlamps dim when turned to the 'start' position?
Any aftermarket alarm or remote-start systems?
Have you tried moving the shifter to N and then tried cranking it?
#5 DaveAdmin
DaveAdmin
    Administrator
  • Supermen
  • 13,858 posts
Posted February 7, 2012 at 04:54 pm
"What do you mean by refilling the tank? "
Just thinking bad gas might be an issue. The key dance would also be a good thing to try. http://www.allpar.com/fix/codes.html
#6 Mred
Mred
  • PipPip
  • 63 posts
Posted February 20, 2012 at 07:12 pm
Problem was a bad starter.
Car Reviews · News ·
Please read the terms of use and privacy policy. We are not affiliated with Chrysler Group, makers of cars, minivans, trucks, and Mopar (TM) parts. We make no guarantees regarding validity or applicability of information, opinions, or advice. Posts may be edited and used in other parts of allpar.com and affiliated Mopar (Dodge, Chrysler, etc) car related sites. We have the right to remove or modify any message, and to ban or suspend any user without notice. Logos and site-specific information copyright © 2001-2010 Allpar LLC; Chrysler PR materials remain property of Chrysler Group.
