Welcome to Chrysler, Dodge, Jeep, Plymouth, and related cars and trucks
Welcome to the Allpar forums for Dodge, Chrysler, Jeep, Plymouth, and other Mopar owners! You must register to post, but this is a simple, free process. Register now or sign in!
95/3.5 Intrepid ES no fuel pressure
#1
Posted February 6, 2012 at 12:21 am
Need little direction. I don't hear the fuel pump come on to put pressure into the system, I also check to make sure that their was no pressure in the line. I check the relay, I believe it is okay. I was checking the power junction box for voltage, and did not getting 12 voltage where pin 86 connect too. I did get voltage where pin 30 plug into on the power junction box. As far as checking the fuse, and fuse area. The fuse is good, but I can't check where fuse plug into very well. I try placing some wires in the slots, but I may have not gotten good contact on the metal to pick voltages.
I am thinking checking the wiring back by the fuel pump, not sure if I should check in different place first.
Any body have suggestions?
Thanks !
#2
Posted February 6, 2012 at 12:54 am
#3
Posted February 6, 2012 at 03:52 am
1) For the few seconds when the key is first turned on. And it will only cycle the pump for a couple of times then stop.
2) When the computer sees the engine is turning (cranking or running). If the ignition is on, but the engine isn't turning there is no power sent to the pump.
#4
Posted February 6, 2012 at 04:27 am
#5
Posted February 6, 2012 at 11:21 am
ImperialCrown, on February 6, 2012 at 04:27 am, said:
THAT is nice to know. Why didn't I know that already? I remember some of the others saying they were cutting holes in the floorpan to access the pump, but you are right, nobody ever did it with an Intrepid. Thanks for this tidbit of information.
#6
Posted February 6, 2012 at 09:08 pm
#7
Posted February 6, 2012 at 09:47 pm
#8
Posted February 20, 2012 at 09:54 pm
Since weather been been nice I can work outside again. I found my problem. Found broken wire back by the fuel pump rather something chew on the blue wire. After soldering wires together my fuel pump is working. Now I just have get new battery since the cold weather did it in since was pretty old.
Thanks for help and suggestion.
#9
Posted February 20, 2012 at 10:18 pm
Home · Cars · Engines · Repairs · People Car Reviews · News · |
hello
View Garage
