cars
96 Breeze gas gauge
5 replies to this topic
#1 slosland
slosland
  • 43 posts
Posted April 20, 2014 at 09:05 am
I disconnected the battery and replaced the fuel pump and the fuel filter on 2.0L. The car runs fine but the needle won't move on the gas gauge.. Bad ground somewhere or something else? 1996 Plwmouth Breeze 169,000 miles.
#2 ImperialCrown
ImperialCrown
  • Supporters
  • Others:Forum Leader
  • 11,774 posts
Garage View Garage
Posted April 20, 2014 at 09:15 am
 Double check your work. Did the pump come with a new sender? Maybe the resistance wiper got bent away from the element or the float arm is being interfered with?
 If you ground the sender wire briefly, the gauge should swing to full. Don't keep it like this for too long, have a helper watching. This will determine whether the problem is inside the tank or not.
  • floridaman2013 likes this
#3 slosland
slosland
  • 43 posts
Posted April 20, 2014 at 09:26 am
ImperialCrown, sender came with the module. So if the gauge swings to full it's in the tank?
#4 ImperialCrown
ImperialCrown
  • Supporters
  • 11,774 posts
Garage View Garage
Posted April 20, 2014 at 11:25 am
 The gauge will swing to full if the signal line is grounded. This can happen inside or outside the tank. Is it pegged on full?
 If you unplug the tank connector and the gauge falls to E, then the short to ground is inside the tank or the float is stuck in the full position.
 If it sits on E, then there is an open circuit for the signal line or the float is stuck in its lowest position.
#5 slosland
slosland
  • 43 posts
Posted April 21, 2014 at 08:14 am
Gauge is currently stuck at 3/4 tank, I will follow yor instructions next weekend when I can get a helper. Will post outcome. Thanks for the info.
#6 ImperialCrown
ImperialCrown
  • Supporters
  • 11,774 posts
Garage View Garage
Posted Yesterday, 02:40 am
 If it is stuck at 3/4 of a tank, it sounds like the float arm may be stuck in this position inside the tank. If the gauge read 'E'. I would suspect an open circuit. If the gauge read 'F', I would suspect a short to ground.
 The positioning arrows on the pump assembly and tank must line up or the float arm can interfere with the inside wall of the tank. If there are fuel hoses tangled inside the tank, they can also interfere with the float arm. This could be giving you your 3/4 of a tank reading.
Tool and Car Reviews · News
