Welcome to Allpar, the Chrysler Car Community
Welcome to the Allpar forums for Dodge, Chrysler, Jeep, Plymouth, and other Mopar owners! You must register to post, but this is a simple, free process. Register now or sign in!
Valve Adjustment 251/265 Flat Head 6 Cyl
#1
Jay Goddard (converted)
Posted December 13, 2004 at 08:47 pm
#2
Operator6 (converted)
Posted December 13, 2004 at 11:01 pm
1. Take a tape measure and starting at the mark on the front pulley measure the circumference of the pulley and divide the pulley in 3rds making a mark with white chalk at each third.
2. Bring the engine up on NR1 TDC which will have the valves on NR1 cylinder closed, set the clearance to specs on both valves, I added a little extra space to make up for it being cold
3. Now knowing the firing order is 1-5-3-6-2-4 turn the engine to the next mark you made on the pulley, this should bring up NR5, set the valves, rotate the next mark to TDC and adjust NR3, rotate to next mark and adjust NR6, Next mark NR2, Next mark NR4. It would probably be a good idea to readjust them after the engine was warmed up but mine was running so good and I could hear the valves ticking a little, and the thought of messing around under the exhaust manifold wasn't too appealing that I just put the covers back on and I"ve not touched it since.....
Good Luck.....RB
#3
Posted December 14, 2004 at 09:38 pm
After doing the valves on my 230 Flathead I adjusted them cold in order to get it started, this may not be the recommended way but it worked....
Good Luck.....RB
#4
Posted December 14, 2004 at 09:41 pm
Good Luck.....RB
Thanks for the information and help. I will try this method out tomarrow. Jay
