cars
Trouble Code P1684
5 replies to this topic
#1 98gcawd
98gcawd
  • 200 posts
Posted May 7, 2006 at 11:58 pm
The other day the malfunction light came on in the 01 Stratus. It just stays on, doesn't flash. I did the key ON/OFF ON/OFF ON and get code P1684. My Haynes manual lists a P1682, charging system voltage indicates low output, but no P1684 - of course! The car runs fine - no problems. Someone got the factory shop manual and can clue me in on the code? The car has the original battery - maybe its on the way out although it starts just fine.
Thanks for any help
#2 howard33x
howard33x
  • 169 posts
Posted May 8, 2006 at 05:58 pm
From another site (http://www.alldata.c.../20021025b.html):
Q: I have a 2000 Dodge Intrepid and the emission light came on. I have two P codes that showed up when I turned the ignition three times P0442 and P1684. I called the dealer and they said they would have to run it on the computer and get the codes. Is this true because I have the codes? If it is not true could you tell me what the codes mean, or what I should do in this situation. I don't want to pay for a diagnostic tests if it is unnecessary.
- Jamie
A: Pretty impressive information for just key cycling for codes. The code P1684 is real easy. The computer is stating that the battery has been disconnected within the last 50 starts. the other code P0442 is a challenge. This code means that the computer has detected an evaporative leak of medium size of about .040 but no bigger than .080 of an inch. The most common cause for this code is a loose gas cap. If the gas cap is tight then it just may be that the gas cap is bad/defective and not sealing properly. Until the problem is found no matter how many times you disconnect the battery (code P1684) to clear the computer the check engine light will turn back on for code P1684.
#3 98gcawd
98gcawd
  • 200 posts
Posted May 8, 2006 at 06:43 pm
Thanks for the reply howard33x,
I thought it was sumptin like that, except that the battery hasn't been disconnected. Might be getting about time to replace the original. From what I understand, I'll need a code scan tool to erase the code and @#%$ dash light!
#4 94Dakota
94Dakota
  • Inactive
  • 14 posts
Posted May 21, 2006 at 10:05 am
According to the software that came with my scan tool:
2000 Intrepid, code 1684 says battery disconnected in last 50 starts
2001 Stratus, code 1684 says "Manufacturer Control Auxiliary Inputs/Auxiliary Outputs" whatever that means...
Good luck
Good luck
Actually, the difference is not between the cars, but the year. 2000 stratus uses this code for battery as well, and a 2001 intrepid uses it for Aux Inputs.Outputs.
#5 juma1998
juma1998
    Moparaholic
  • 2,429 posts
Posted June 4, 2006 at 05:25 pm
Go to Autozone or Advance Auto they have scanners. And will let u PERSONALLY delete the codes - as they cant delete the codes anymore themselves. I was told they were blowing up Computers cause ppl kept coming in and having them delete codes. Sounds fishy but U can definately have them let u delete it.
#6 Tek286
Tek286
  • Inactive
  • 305 posts
Posted June 12, 2006 at 08:18 pm
Error code P0442 = Click Here:>P0400 to P0485
Error code P1684 = Click here:>P1600 to P1699
Edited by Tek286, June 12, 2006 at 08:23 pm.
Tool and Car Reviews · News
