cars
The latest Mopar news: No summer vacation for many Chrysler plants • Fiat Industrial/CNH to be a UK citizen
The week’s features: Top 5 Missing Mopars  •  Sgt Bob Phillips, Police Car Pioneer  •  Imperial production and history  •  Ramchargers: Funny cars, Clorox, and riots
Welcome to Allpar, the Chrysler Car Community
Welcome to the Allpar forums for Dodge, Chrysler, Jeep, Plymouth, and other Mopar owners!  You must register to post, but this is a simple, free process.
Register now or sign in!
  • Use the collective Mopar knowledge of the community
  • Post, reply, and subscribe to topics
  • Make new friends
  • Join us at our annual meets
Guest Message by DevFuse
Lower Ball Joint Wont take Grease?
7 replies to this topic
#1 bill
bill
    Part of the Community
  • PipPip
  • 169 posts
Posted January 19, 2007 at 04:40 pm
I have our Caravan up on jacks putting on new struts and decided to do a lube to finish things off. The problem is the lower ball joint on the passenger side won't take grease. I removed the fitting and put it on the grease gun to make sure that wasnt the problem. Grease blew thru it. I got underneath and put a small screwdriver into the hole and gently cleaned out some old grease and thats about it. I dont know what I should feel but the screwdriver hits a flat solid surface. As this is a new addition to our elderly Chrysler fleet this is my first lube job. The rubber fitting is deflated and doesn't appear to have much grease inside. The van has 116,000 miles. A couple weeks ago when I tried to move both lower ball joint fittings(when on the ground) to see if there was any movement I detected nothing. It steers well without any shimmy or shakes. Any ideas, thanks everyone :rolleyes:
#2 dana44
dana44
    Posts Coming Out in Encyclopedia Form Soon
  • PipPipPipPipPipPipPip
  • 15,392 posts
Posted January 19, 2007 at 04:50 pm
I have had joints like that too. If the zerk fitting itself is OK, put it back on and you are really going to have to squeeze hard. I have had them that way before, they just get enough grease and metal powder from years of use and get a little bit jammed up. Really crank on it to force the jammed holes. There are grooves around the ball type joints to take grease and be able to cycle up to the rubber cup, plugged is plugged, until you force it through, next time will be a little easier. I am pretty strong and have had to brace the gun barrel against my chest and double-handed squeeze a couple times to get them clear in the past. Good luck.
#3 KOG
KOG
    KOG
  • 5,657 posts
Posted January 19, 2007 at 07:36 pm
I'd replace the zerk fitting first anyway. It's possible for them to pass grease when open but have the check ball jam shut under pressure.
#4 bill
bill
  • PipPip
  • 169 posts
Posted January 20, 2007 at 09:02 am
Thanks for your help! Do you think it would help to apply heat(very gently) to the assembly to loosen up the grease inside or could that just lead to damage? :blink:
#5 tealfish
tealfish
    Unusually Active
  • Inactive
  • PipPipPipPip
  • 2,224 posts
Posted January 20, 2007 at 12:26 pm
Hold a hot soldering iron into the grease fitting hole and see if that will loose things up to the point where it will accept grease.
#6 Bob Lincoln
Bob Lincoln
    "CHECK FAULT CODES"
  • Forum Leader
  • PipPipPipPipPipPipPipPip
  • 23,784 posts
Posted January 20, 2007 at 02:10 pm
Jut buy a new grease fitting. They're pennies apiece.
#7 dana44
dana44
  • 15,392 posts
Posted January 21, 2007 at 05:28 am
As bill said, the fitting itself isn't the problem, it is compacted grease and grime/powdered metal inside that is jammed and plugged, a propane torch may help a little, so long as it doens't damage the rubber boot on the joint, the rest is metal and grease, a soldering iron wouldn't put enough "even" heat around it to soften up the existing grease, try about a minute with a propane torch, moving it around to "warm" it up vice getting it red hot, which shouldn't be close to long enough, should cause absolutely no damage, but like I said, watch the rubber boot. Good luck.
#8 bill
bill
  • PipPip
  • 169 posts
Posted January 21, 2007 at 09:36 am
Thanks to all that posted!! I was concerned maybe the joint had seized. Dana44, I really appreciate your post explaining how there are 'veins' along the ball joint allowing the grease to flow into the boot. I didn't have that knowledge making me think the worst had happened. Last night I took my tourch and lightly went around the bottom of the joint, just enough to warm it up. I squeezed the gun and what a wonderful feeling when the handle began to slowly compress!!! :rolleyes: This forum and its members are better than any shop book! Maybe someday I can share something I've learned here on Allpar!! :P
[Topic Google Ads]
Car Reviews · News ·
Please read the terms of use and privacy policy. We are not affiliated with Chrysler Group, makers of cars, minivans, trucks, and Mopar (TM) parts. We make no guarantees regarding validity or applicability of information, opinions, or advice. Posts may be edited and used in other parts of allpar.com and affiliated Mopar (Dodge, Chrysler, etc) car related sites. We have the right to remove or modify any message, and to ban or suspend any user without notice. Logos and site-specific information copyright © 2001-2010 Allpar LLC; Chrysler PR materials remain property of Chrysler Group.
