cars
Low speed wheel wobble / shimmy
3 replies to this topic
#1 tonylewis (converted)
  • Guests
Posted May 8, 2007 at 08:37 am
I recently sold my 96 Intrepid with only a few miles short of 200K, and "inherited" my daughter's 99 Cirrus with only 100K miles. It has a low speed wheel wobble or shimmy that occurs on slow down and speeding up. Here's the diagnostics to date:
1) right front wheel appears to wobble at low (<30 mph) speed, both slowing down and speeding up
2) steering wheel does NOT wobble/shimmy
3) no clicking noises from CV
4) vehicle tracks perfectly - no pulling left or right
5) wobble / shimmy would seem to appear when braking, indicating warped rotors, but continues if you take foot off of brakes, and continues when speeding back up.
6) wobble / shimmy apparently does occur on turns at low speed, both left and righ
7) absolutely no wobble or shimmy at highway speeds
8) having car in drive or neutral makes no difference
Surfing this forum and the web often points to a similar problem with the minivans and their inner CV joint, but that seems to apply to wobble on acceleration only. To date, I have not done any of the "simple" stuff such as rotating tires (bad tire), turning rotors (warped rotor), checking tie rods and ball joints, or front end alignment. I am getting a lot of things fixed at one time in the near future, because I will be changing the stock steel wheels for some original aluminum wheels, and then rotating tires and getting front end aligned. Just wanted to throw this out there to see if there are other things to look for. The thing that is strange to me is that the steering wheel does not wobble or shimmy at all when the car does. Thanks!
Edited by tonylewis, May 9, 2007 at 10:40 am.
#2 KOG
KOG
    KOG
  • 5,837 posts
Posted May 8, 2007 at 05:39 pm
You already know. Start with the simple stuff.
#3 tonylewis (converted)
  • Guests
Posted May 9, 2007 at 07:28 am
You are right. It will be interesting to see if it gets any better after the simple/quick/cheap stuff is done.
#4 68RT
68RT
  • 4,597 posts
Posted May 9, 2007 at 12:16 pm
Your style shimmy is very common with a broken belt in a radial tire. The fact that it continues with the brakes off usually will eliminate the brakes as a primary (may also be an additional problem) source of your complaint. I would look at tires first, then u-joint second. Many times the tire can be spotted by just jacking up the wheel just off the ground with the trans in neutral (Make sure the parking brake is applied!) and rotating the tire while watching the tread at the bottom (ground used as a reference) for odd movement.
Tool and Car Reviews · News
