cars
Random Multiple Cylinder Misfire
4 replies to this topic
#1 sst1226
sst1226
  • Invalid E-mail - contact admin
  • 49 posts
Posted July 24, 2007 at 01:47 pm
My 98 Cirrus 2.5L occasionally will store a code/codes for "multiple cylinder misfire" or "misfire cylinder #X" or both. It usually happens when travelling at 60-75 mph for an extended period of time with tempatures above 85 Deg. F. with the A/C on.
Usually the check engine light will flash. If I stomp on the throttle the light will go off. Sometimes the light will come back on and stay on for a little while before going out, or just flash a few times and then go off. When I retrieve the codes, I get the misfire messages.
I did a tune-up about 30,000 miles ago with Cap and Rotor, Wires and Champion OE plugs. The O2 sensors were replaced about 40-50,000 miles ago.
I suspect it could be bad plug wire/wires or perhaps too much discount gas without use of a good fuel system cleaner.
Any suggestions?
#2 Gerry G
Gerry G
  • 752 posts
Posted July 24, 2007 at 09:42 pm
I had a bad crankshaft position sensor that would act up at times and cause a multiple misfire. Unfortunately I had just
replaced the sensor and it was the new one that was bad. the second sensor was better but still not perfect. I went out
and bought an oem one and have not had a problem since (do check out the price from a dealer, I was surprised to find out
the dealer one was actually a buck or so cheaper).
Hope this helps,
Gerry G.
#3 SuperShadow
SuperShadow
  • 344 posts
Posted July 27, 2007 at 10:15 am
Maybe you have a "trial version" of the MDS that is all the rage today!! (sarcasm)
Hey, it's Friday and I think everybody could use a little humour about now!!! :P
SuperShadow
#4 Stratuscaster
Stratuscaster
    Vaguely badass...
  • Supermen
  • Others:Supporters
  • 19,629 posts
Posted July 27, 2007 at 10:18 am
Or the distributor has developed a crack...
#5 sst1226
sst1226
  • 49 posts
Posted August 8, 2007 at 08:03 am
Hope this helps,
Gerry G.
I replaced my Crankshaft Position Sensor back in Dec. with one from Napa. In the last month, I've had the check engine light coming on. It doesn't seem to sputter or break up when the light comes on. I suppose it wouldn't hurt to try one from Chrysler. I'll try it and let you know, thanks for the advice!
Tool and Car Reviews · News
