1956 Plymouth Savoy brake drums
Discussion in 'Other classic cars' started by Dad-Par, Aug 15, 2017.
  1. Dad-Par
    Dad-Par Member
    Sep 19, 2014
    23
    1
    Hello, Good Morning! Joined after buying and, with your help, restoring a '64 Belvedere, but now looking at a '56 Plymouth Savoy 2 dr sedan 230 - 6, w/Powerflite auto trans. Have not purchased yet, would like to check out parts avail first. Seem to be having difficulty locating front 10" brake drums and front shocks (spring over) for this car. Are they avail? And does this car have u-joints or cv type on drive shaft. Every time I look up u-joints (anywhere), if anything comes up it's a cv joint repair kit. And other than a trans pan gasket that is avail, is there a 'filter kit' (does trans have a filter?) Any thoughts? Thanks!
  2. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    5,527
    446
  3. 68RT
    Aug 8, 2003
    5,527
    446
    You might want to follow this thread in this forum "Starting on a '55 Plymouth Plaza Suburban". He updated a lot of things if you do not want concurs. Lots of pictures to go with it.
    Bearhawke likes this.
  4. Dad-Par
    Dad-Par Member
    Sep 19, 2014
    23
    1
    Thanks 68RT
  5. 71Charger_fan
    71Charger_fan Active Member
    Aug 1, 2014
    289
    187
    Since I went with modified Corvette shocks on the front of my '55, I have a pair of NORS front shocks I didn't use if you buy the '56.
  6. Dad-Par
    Dad-Par Member
    Sep 19, 2014
    23
    1
    Thx 71Charger-fan, will keep in mind.
  7. GaryS
    GaryS Well-Known Member
    Aug 24, 2004
    1,484
    191
    I used Corvette shocks on my '56. The only mod they need is slightly enlarging the slot for the lower mounting bolt.
    Due mostly to the limited availability of aftermarket parts for '55-'56 Plymouths, I made lots of mods on mine.
    https://56plymouth.blogspot.com/
  8. Dad-Par
    Dad-Par Member
    Sep 19, 2014
    23
    1
    Thx GaryS
