1964 or 1965 426 hemi
Discussion in 'Projects, mods, restoration' started by chgohr, May 29, 2017.
  1. chgohr
    chgohr Member
    Mar 11, 2017
    1
    I have a May 1964 426 Hemi engine I need help identifying. 2468330-2 casting 5 4 64 below also on the casting. Stamped on the deck
    AH426HC
    11 10 03 and WT. Any help is appreciated.
  2. hemirunner426
    Mar 19, 2013
    666
    416
    That's the casting number from 1964-1971...Does it have Aluminum heads?
  3. Scrounge
    Scrounge Well-Known Member
    Apr 30, 2009
    1,517
    240
    The A in AH426HC is the year code, and stands for 1965. The engine codes begin with M for 1959, P for '60, R for '61, S for '62, T for '63, V for '64 and A for '65. The number beneath that is build date: 11 is the month (November, probably 1964), 10 is the day, and 03 is the build sequence. Someone else will have to help you with the WT, but it might mean that it was built in Windsor.
  4. hemirunner426
    Mar 19, 2013
    666
    416
    WT stands for water test,i think.
    Scrounge likes this.
