NewsWhat’s special about the Demon? • Demon has a freakin’ TransBrake • Pritchett’s Challenger Drag Pak isn’t a Demon
1977 Chrysler LeBaron 4-door base model owner.
Discussion in 'F-J-M: Volare, Diplomat, etc, 1977-89' started by 77LeBaron, Feb 3, 2017.
  1. 77LeBaron
    77LeBaron Member
    23
    Citation on Youtube they have a ton of Mopar comparison tests posted by a youtuber called Osborne Tremain and others . I lover the front end styling and rear deck lights . The Lincoln was just an upscale Mercury Monarch out of the three Seville, Versailles both 12 grand , and the LeBaron 7 grand maxed out the LeBaron was the best , but I am biased, I have driven them all and the interior of the LeBaron is by far the best of the bunch .
    Citation84 likes this.
  2. 77LeBaron
    77LeBaron Member
    23
    I hear what you are saying the power window swap is a long shot yet if the opportunity arises I will do this. I am shopping around for the 2 door and 4 door LeBaron in leather trim and maxed out on options they do turn up well maintained for about 5 grand .
  3. 77LeBaron
    77LeBaron Member
    23
    Found the Chrysler Master Tech - 1977, Volume 77-4 LeBaron and Diplomat Technical Highlights
    View: https://www.youtube.com/watch?v=O5QdISCvt_0
    and starting at 3:17 and at 3:40 the object of my complicated repair the high capacity heater core . I am a novice to car A/C and heating systems but have really never seen an A/C evaporator inside the dash . I am educating myself on the A/C , Heater system and it looks like I will be taking it to a Mechanic due to the fact the A/C must be taken apart also and I have no way to capture the Freon from the system.
  4. 77LeBaron
    77LeBaron Member
    23
    Here is a great video 1971 Dodge vs. Chevrolet Light Duty Trucks and Vans Dealer Promo Film I get a kick out the interplay between the young and fertile Irma F. Smith and the boss Big Sam Saavy !
    View: https://www.youtube.com/watch?v=6JRP-5zpOGI
  5. Citation84
    Citation84 Member
    284
    Didn't know there was video ! Thanks for that. Old road tests and "first start after 40 years" videos are my favorites.
  6. Citation84
    Citation84 Member
    284
    Will you retro-fit to be able to use the new refrigerant ?
  7. 77LeBaron
    77LeBaron Member
    23
    I have thought about the retrofit it might be time to change out the A/C hoses , dryer etc while I get the heater core fixed. The master tech series is a vault of information !
  8. valiant67
    valiant67 Rich Corinthian Leather Level III Supporter
    8,574
    The newer cylindrical compressors do better than the old RV2 when changing to newer refrigerant. You might consider this, the cars changed compressor styles around 1989.
  9. geraldg
    geraldg Active Member Ad-Free Member
    588
    I think they changed earlier than that I had a 87 5th ave that had the newer type.
  10. valiant67
    8,574
    Oops meant 1980!
    Bearhawke and geraldg like this.
  11. 77LeBaron
    77LeBaron Member
    23
    Hi My latest concern is now my ignition . I have noticed lately thay my ignition will click but not turn over on a more frequent basis. What could be the cause of this . It took many times today , then later it cranked on the first try . Experts please offer a diagnosis .
  12. valiant67
    8,574
    If you mean the starter is clicking rather than spinning the engine start by inspecting for corrosion at the battery then follow the cables to the starter checking connections. But the problem may we'll be the starter itself.
  13. 68RT
    68RT Active Member
    349
    More likely the solenoid than the starter itself.
  14. Scrounge
    Scrounge Member
    148
  15. Bearhawke
    Bearhawke Things happen for a reason
    271
    Def 1980 although the newer style AC compressor was phased in during the 1979 model year. I don't remember seeing an Old School York compressor on any R body V8.
