AF: 1978 B series van remove instrument cluster | Allpar Forums
Discussion in 'Vans' started by skloon, Jul 5, 2016.
  1. skloon
    skloon New Member
    Aug 23, 2011
    11
    I have to fix the gauges and I have a 77 service manual, anybody have a copy of a 78 up one that shows how to remove this ?
    ImperialCrown Moderator
    20,957
    4,165
    Disconnect the battery. The ammeter wires are hot and can short on the sheetmetal dash as you remove it.
    Reach up underneath and disconnect the speedometer cable. There should be a pinch-tab where it attaches to the back of the speedometer.
    Any Dodge/Plymouth B-van shop manual from '71-'78 should be the same. Check your main library?
    P.S. - I believe that the steering column has to be dropped down to get the cluster past it.
  3. skloon
    skloon New Member
    Aug 23, 2011
    11
    Thanks- it was easier that I feared- mine is a 78 but has a 79 or later dash- the pins on the circuit board are snapped off so I have some work in front of me
