1986 Dodge 2.2 crankshaft main bearing caps
Discussion in 'EEK! - Every Extended-K Car' started by andybuzz2u, May 6, 2017.
  1. andybuzz2u
    andybuzz2u Member
    Mar 23, 2004
    25
    1
    Does anyone know where I can get a set of main bearing caps?
  2. dana44
    Ad-Free Member
    Jun 17, 2002
    19,326
    1,238
    Main bearing caps stay with the block itself, or basically, shouldn't be swapped around unless you also line bore the main bearing saddles, so, if you need a set of main bearing caps you most likely have to get them off another 2.2 engine (I think they are the same as the ones on a 2.5), and then have them properly sized to the block. I suggest a salvage yard for the first part, a machine shop that can line bore a block, second.
  3. andybuzz2u
    andybuzz2u Member
    Mar 23, 2004
    25
    1
    Yeah, I know all of that. I would like a new set. They only made a gazillion 2.2's so surely new main bearing caps are out there.
  4. manybrews
    manybrews Active Member
    Jan 10, 2014
    111
    25
    You would probably be better off finding a used bare block with the caps.
    Wouldn't require machining, and I would think you could pick one up cheap.
    pt006 likes this.
  5. dana44
    Ad-Free Member
    Jun 17, 2002
    19,326
    1,238
    Yes, they did make an awful lot of them, but no, unless you find aftermarket, they are kind of like finding rod caps by themselves, they just aren't around like that to purchase, they come with the block. But, like I said, might be able to get aftermarket, beefier ones that would still need to be line bored after installation.
  6. 85lebaront2
    Jun 24, 2017
    92
    19
    If you want a set, I have a 2.2L long block I am going to scrap (it was apparently run very low on oil, #1 cylinder wall looks like it has furrows in it). I will gladly pull them off and if the mains haven't spun in them you are welcome to them.
  7. pt006
    pt006 Active Member
    Dec 24, 2014
    1,288
    492
    Before you leap, find a machine shop that does this type of work and ask them the cost.
  8. andybuzz2u
    andybuzz2u Member
    Mar 23, 2004
    25
    1
    If you still have them I would be interested.
