1986 OMNI TURBO: FEB.22,1986: HAPPY ANNIVERSARY !!
Discussion in 'L: Horizon/Omni, Rampage, etc' started by GLHS60, Feb 22, 2015.
  1. GLHS60
    GLHS60 Well-Known Member
    Jun 23, 2008
    1,403
    374
    I bought my Black 1986 Omni Turbo Feb, 22, 1986, the car in my avatar, and its still in my garage today!!
    It was a great reliable, economical and fast friend for the initial few years and in 1997 I installed the complete 300 H.P. Super 60 system for even more fun!!
    Thanks
    Randy
    71Charger_fan, PCRMike and wtxiceman like this.
  2. 88horizon5speed
    Aug 12, 2013
    208
    14
    Wow, that's really awesome! Congrats! If you have time would you mind sharing how many miles it has, and what issues it has had over its life?
    Also out of curiosity how much in the way of rust do you have? I'm assuming you don't drive at all in the winter anymore to keep it from rusting...I'm hoping to have my 88 be its last winter and get a truck as a dd to save this car
    #2 88horizon5speed, Feb 23, 2015
  3. GLHS60
    Jun 23, 2008
    1,403
    374
    I appreciate the kind words!! I never had any problems with the car and when Mopar offered the Super 60 deal I bought the entire setup back in 1997. The Super 60 was advertised as 300 H.P. at 18 psi. but I often run 24, via a switch mounted on my shifter allowing instant boost settings of 6-12-18-24 psi at the flick of the switch. He really doesn't have any rust but I try to keep care of him, especially at his age. The odo is at about 78,000 km presently.
    Its nice you are giving your 1988 good care as they are getting scarce, very easy model to Turbo if one is bent that way!!
    Thanks
    Randy
  4. 88horizon5speed
    Aug 12, 2013
    208
    14
    Thats awesome to hear, and thanks Ive gained a liking to the car in the two years ive owned it. I wish I could have owned it since new
  5. Donnie 3.0
    Donnie 3.0 Well-Known Member
    May 25, 2004
    764
    48
    Hey, Congratulations, Randy!
    That's impressive!
  6. GLHS60
    Jun 23, 2008
    1,403
    374
    I appreciate the kind words guys!!
    Thanks
    Randy
  7. RamDakDust
    RamDakDust Member
    Dec 14, 2011
    40
    5
    Congrats! Always got a kick out of those cars. Glad to see one got a good home and appreciated the way it should be.
  8. turboomni
    turboomni New Member
    Jun 22, 2016
    6
    2
    I have a Omni glhs and went the super 60 route back in the day. What I didn't like was the fact there was no knock sensor input so you had to run race gas all the time. I have remedied that and gotten rid of the super 60 type cam which only lasted 25,000 miles. I went to a roller with a milder profile. Still have the viper fuel pump in it which will be changed out soon. I found my Super 60 wiring harness's knock sensor circuit was basically disabled from the factory the way it was wired. I fixed that. So I went to a different computer [smec] with an aftermarket calibration with knock sensor input.
    Kept the +40 injectors. Not as powerful as before but still crazy compared to a glh turbo which I owned also with the mopar computer.
  9. GLHS60
    Jun 23, 2008
    1,403
    374
    My Super 60 cam is still in nice condition but many others had problems. I used secret cam lube, cam caps with oil squirters and unrestricted head oiling, it might have helped or I was just lucky!!
    I also have a custom SMEC with enhanced cruise control and it works nicely along manual boost control.
    I have a heater switch on my shifter, 6-12-18-24 PSI at the flick of the switch !!
    I installed the big Bosch in my tank as it was too noisy externally mounted.
    Thanks
    Randy.
  10. ka9yhd
    ka9yhd Active Member
    Aug 17, 2013
    1,158
    220
    Very nice. Are you still running the stock A525 trans with 300 hp?
  11. GLHS60
    Jun 23, 2008
    1,403
    374
    No, I replaced it with an A-555 from a Shelby Z that I used as a donor car for my build.
    The Shelby Z also donated its wheels, shifter, cables, rear discs, cruise control and short block with forged crank and probably a few more bits.
    I really liked the little smooth shifting A-525 but knew it wouldn't take much power.
    The A-525 also had a shorter final drive ratio for more relaxed highway cruising.
    Thanks
    Randy
    Most recent picture:
  12. turboomni
    Jun 22, 2016
    6
    2
    No way 525 would hold up as I went to a 555 also with custom axels and a forged crankshaft. A secret cam lube huh>? Is it top secret? I did not remove the oil restrictor in the head but did use the mopar upgrade oil pump which makes crazy psi. I know psi does not = flow..but still the S60 cam wore out actually at a higher milage than most. The squirters maybe the key. Too bad but I won't go back.
  13. ka9yhd
    Aug 17, 2013
    1,158
    220
    My friend used to own a 1987 Omni, no turbo, that had the A525 in it and he prefers the gear ratios in the Omni versus his 02 Neon with the 5 speed. As he would get a little better fuel mileage out of the Omni. He claims the engine revs a little to high compared to the Omni.
    I had a 1987 Shelby CSX which Shelby could not get the Turbo II from Chrysler so he modified the Turbo I into a Turbo II and it still had the A 520 trans. So Shelby had to de-tune the torque.
    I had nothing but trouble with that cable shifter as it would jamb or not go into a gear. I was constantly adjusting and playing with the shifter and cables.
    I drove a few other Shadows with the 5 speed and the gear shift lever felt different in each car. One Shadow I drove, when shifting from 1st into 2nd gear the lockout for reverse would take a hop and you could feel the lever jump.
    #13 ka9yhd, Jun 24, 2016
  14. turboomni
    Jun 22, 2016
    6
    2
    There is an adjustment of what you are talking about. I hacked a bunch of cables from the junk yard so I could see what worked best as far as length. There are adjustments you can make ,making sure the cables are secure and a pin if I remember you reversed and then adjusted the throws from the shifter. This was in the early 1990"s when I did this.
  15. ka9yhd
    Aug 17, 2013
    1,158
    220
    And that is the adjustment I was doing as per the service manual.
  16. GLHS60
    Jun 23, 2008
    1,403
    374
    It's that time again!!
    31 years today since I bought my Omni Turbo.
    Thanks
    Randy
    PCRMike and Bob Lincoln like this.
  17. Fast Eddie
    Fast Eddie Valued Member
    Jun 12, 2014
    1,511
    1,364
    Sweet! One of the best "giant killers" we ever made.
  18. GLHS60
    Jun 23, 2008
    1,403
    374
    Right on Fast Eddie!!
    My internet pal James Reeves is still killing it, 9.99 !!
    Thanks
    Randy
    Broke the crank!!
