AF: 1987 Omni brake proportioning valve | Allpar Forums
Discussion in 'L: Horizon/Omni, Rampage, etc' started by chadnyne, Sep 21, 2019.
  1. chadnyne
    chadnyne Active Member
    Aug 8, 2013
    31
    2
    anyone have a suggestion for a replacement brake proportioning valve for an 87 Omni? Don’t appear to be obtainable. Are any of the universal ones a direct fit?
  2. GLHS60
    GLHS60 Well-Known Member
    Jun 23, 2008
    1,785
    584
    It looks like 4313266 is the Chrysler part # and it should have a grey tag.
    1987 Dodge Omni Lines & Hoses, Brake - Mopar Parts Giant (at https://www.moparpartsgiant.com/parts-list/1987-dodge-omni/brakes-service-lines-hoses-brake.html )
    Grey L, J, P body
    L body: Omni/Horizon: J body: LeBaron/Lancer P body :Shadow/Sundance
    Some with front disc rear drum should be compatible if lconsidering used.
    They seldomly fail so new aren't often available.
    These have diagonal braking so universal might br a challenge.
    What happened to yours??
    Thanks
    Randy
    Differential and Proportioning Valves from: Mini-Mopar Turbo Performance (at http://www.minimopar.net/perf/brakes.html )
    Brake systems distribute the pressure from the master cylinder through a differential valve. These function by splitting the two master cylinder outputs between the left-front and right-rear brakes and vise versa. This way if one set fails, the other set can still stop the vehicle because the brakes are split diagonally from each other. In most cases, pressure to the rear brakes has to be reduced. This is accomplished through a proportioning differential valve. There are several different proportioning valves available, depending on the brake system combination your vehicle has. They function by reducing the amount of brake fluid pressure to the rear brakes after a certain input pressure point, called the split point. The ratio by which the rear brake pressure is reduced after the split point is called the proportioning slope. The lower the slope value, the more the pressure to the rear brakes is reduced. So, if you find that your rear brakes tend to lock up prematurely, then you need a valve with a lower slope and/or lower split point. A perfectly balanced brake system does not need a proportioning valve. Instead these use a basic differential valve that have no proportioning feature, and therefore have no split point and have a slope of 1. Stock proportioning valves are identified by the color of the indent tag. Below is a chart of available valve configurations.
    Tag Color Function Material Split Point Slope
    (none) Differential Brass - 1
    Grey Differential-Proportioning Brass 500psi 0.27
    Tan Differential-Proportioning Brass 600psi 0.43
    White Differential-Proportioning Brass 750psi 0.43
    Black Differential-Proportioning Brass 800psi 0.59
    This table shows some of the vehicles that these valves were used in. Some bodies had different valves depending on their brake configurations (disc/drum, disc/disc, ABS, etc) and specific body styles (2-door, 4-door, etc).
    Tag Color Bodies
    (none) E
    Grey L, J, P
    Tan K, P
    White G, H
    Black G, K
  3. chadnyne
    Aug 8, 2013
    31
    2
    Have no pressure to passenger front only
  4. chadnyne
    Aug 8, 2013
    31
    2
    Read somewhere issue could be collapsed brake hose. Will try replacing this first since it is a $3 part...
  5. ImperialCrown
    ImperialCrown Moderator
    20,535
    3,867
    Is the red 'BRAKE' light on and do you have fluid flow to the driver's rear brake wheel cylinder bleeder?
    It could be that the 'shuttle' in the proportioning valve is forced to one side? This would shut off flow to a diagonal braking circuit.
  6. chadnyne
    Aug 8, 2013
    31
    2
    No brake light on
  7. GLHS60
    Jun 23, 2008
    1,785
    584
    Typically a collapsed hose will prevent the caliper piston from retracting.
    This normally results in the brake staying on not off, just like a stuck caliper.
    Stuck calipers normally result in the brake stuck on, not off, but anything is possible.
    As IC asked, do you have flow to the LR??
    And is the brake warning light functioning otherwise??
    IIRC, with ign on, grounding the wire that attaches to the prop valve should turn the light on.
    This test verifies the bulb and wiring etc. is capable of warning owners of hydraulic problems.
    Thanks
    Randy
  8. chadnyne
    Aug 8, 2013
    31
    2
    Bought car with stuck caliper. Stuck on. Replaced caliper but noted no brake fluid coming out of the hose when I detached it. No fluid even with power bleeder.
  9. chadnyne
    Aug 8, 2013
    31
    2
    Per the brake light grounding test, brake light is working. The brake light has not been on otherwise. I will check flow to the LR when I get a chance
  10. GLHS60
    Jun 23, 2008
    1,785
    584
    That sounds more like possible hose issue.
    Thanks
    Randy
    Gerry G and Bob Lincoln like this.
  11. chadnyne
    Aug 8, 2013
    31
    2
  12. chadnyne
    Aug 8, 2013
    31
    2
    Just a follow up, replaced hose to caliper and brake line which resolved this. Proportioning valve was not at fault
    ImperialCrown likes this.
