AF: 1994 Chrysler LHS Braking issues | Allpar Forums
Discussion in 'LH: Large Cars, 1993-2004' started by JerCrest01, Jun 3, 2019.
  1. JerCrest01
    JerCrest01 New Member
    Mar 18, 2016
    16
    Hello,
    I replaced my axles, and front bearings, and after that my brakes are acting up. I stem on the pedal and it pulses, and does nothing.
  2. valiant67
    valiant67 ...
    36,664
    19,404
    Sounds like the car has ABS and something is wrong in that system. Did you use the proper ABS parts? Any sensor damaged or unplugged?
  3. ImperialCrown
    ImperialCrown Moderator
    21,188
    4,387
    Are the toothed ABS tone wheels on the replacement axles?
  4. JerCrest01
    Mar 18, 2016
    16
    I did use the abs tone axles. I had to use a rubber mallet to get the old bearings off of the spindles to replace the axles, would this cause abs sensor damage?
  5. JerCrest01
    Mar 18, 2016
    16
    Follow up, I went on a test drive and the same issue came up after i changed the abs sensors, my brother suggested that I pull the fuse on the ABS and the issue went away. However is there anyway to see if the ABS system is malfunctioning? Motor or wiring ect.....
  6. valiant67
    valiant67 ...
    36,664
    19,404
    You’ll need an advanced scan tool that can read the ABS computer on the car to diagnose.
