AF: 1999 3.3l Caravan to 2006 3.3l caravan | Allpar Forums
Discussion in 'Minivans · Pacifica' started by Jasaa Weld, Sep 5, 2017.
  1. Jasaa Weld
    Jasaa Weld Member
    Sep 5, 2017
    1
    Hey guys, I just got done bolting in the 2006 into the 99 van, I'm looking for advice and tips in finishing the project, all the mounts lined up great! ive got the power steering hooked up, ive switched the throttle cables and hooked up, I'm down to the electrical... Is there anything that I should be expecting? I will be starting back on it today around 5pm
    Thanks!!
    ImperialCrown Moderator
    21,198
    4,400
    Welcome to Allpar. The 2006 would have on an NGC (next generation controller) powertrain controller and supporting circuitry. The 1999 used the old SBEC (single board engine controller) powertrain controller and isn't really compatible.
    You may have to swap the cam sprocket and flexplate to the old style?
  3. ka9yhd
    ka9yhd Well-Known Member
    Aug 17, 2013
    1,322
    275
    Also some of the sensors might of been moved around on the engine. And the mounting for some of the sensors might be cast into the block and heads could of been moved around over the years.
    There is a compatibility list of which engines will fit which vehicles.
  4. valiant67
    valiant67 ...
    36,682
    19,435
    You are going to be limited by the 1999 electronics. I'm not surprised it fit physically, but I'm worried if it is going to run well, if it even runs.
    Doug D likes this.
  5. GLHS60
    GLHS60 Well-Known Member
    Jun 23, 2008
    1,969
    671
  6. Mile011
    Mile011 Well-Known Member
    Sep 2, 2012
    190
    34
    All i can say is
    Good luck
    I hope you are done since this was 2 weeks ago.
    I am sure there a few people who would like to hear how it went.
