20 amp fuse 2013 Ram
Discussion in 'Ram, pickups, commercial trucks' started by 48jeep, May 18, 2015.
  1. 48jeep
    48jeep Member
    Aug 6, 2014
    35
    9
    I blew the 20 amp fuse for the trailer lights and I haven't been able to find one. I have tried Autozone, O'Reillys and Pep Boys but no luck. Does anyone have any suggestions where I can find one? I haven't seen one like this before.
  2. NYBo
    Jan 3, 2005
    4,132
    91
    Do they look like this?
    [​IMG]
    I found them on RockAuto.com, listed as "female fuses".
  3. ImperialCrown
    18,221
    2,654
    A good auto parts store should have the above J-case cartridge-style. The fuse type should be printed on the fuse.
  4. 48jeep
    48jeep Member
    Aug 6, 2014
    35
    9
    I went to four different part stores and none had one. NAPA didn't show one in their 2015 catalog. It does look similar to the ones pictured but the case is shorter. I ended up going to the dealer and ordering one for about ten dollars. I believe it is an "M" case.
  5. dak4x4
    dak4x4 Member
    Sep 19, 2012
    699
    179
    $10 for something designed to blow; ouch!
  6. ImperialCrown
    18,221
    2,654
    MoparNorm likes this.
  7. 48jeep
    48jeep Member
    Aug 6, 2014
    35
    9
    Thanks Imperial Crown. I hope I don't have to get another one but if I do I will check with these guys.
  8. kman614
    kman614 Member
    Nov 17, 2017
    1
  9. ImperialCrown
    18,221
    2,654
