2002 SEBRING COUPE POWER LOSS
Discussion in '200, Avenger/Sebring, Cirrus/Stratus/Breeze' started by TEDDZ, Dec 10, 2017.
  1. TEDDZ
    TEDDZ New Member
    Dec 10, 2017
    3
    1
    I Have a 2002 Sebring coupe with a 3.0 liter and im to solve issues with my car. I had a run problem last year no power and misfires, i replaced mass air flow sensor map sensor and finally replaced the distributor and the problem was solved, Unfortunately the catalytic converter bank 1 was damaged from misfires I replaced the cat with a walker ultra converter and 2 new o2 sensors upstream and downstream Denso. the car starts and runs when putting a load on the motor it will downshift and not up-shift unless gas pedal is released and lite throttle applied, power flattens out.
    18,326
    2,697
    Welcome to Allpar. So this power loss has only been since the cat and O2 sensors replacement?
    Do the spark plug tips indicate any rich (black) or lean (white) issues? Are the Fuel Trim or Adaptives showing positive (adding fuel) or negative (removing fuel)?
    There was a spark plug update mentioned in TSB 18-030-05 to Champion RC10PYP4. Are the plugs correct and have they been done? Since the upper intake has to come off, you may as well replace wires too.
    The other portion of the TSB details an ECM software update that addresses cold start and performance issues. Most FCA dealers should be able to do that if it hasn't been done:
    Score! Im about to pull the trigger on a '02 Sebring coupe... (at https://www.allpar.com/forums/threads/score-im-about-to-pull-the-trigger-on-a-02-sebring-coupe.161953/ )
  3. TEDDZ
    TEDDZ New Member
    Dec 10, 2017
    3
    1
    I looked at it today and i think i have cat material blocking the exhaust, I hit the exhaust with a rubber hammer and rattles were heard, the inside of the old cat had material missing, Im going to take it off next weekend, thanks for the added help.
  4. ImperialCrown
    18,326
    2,697
    Yes. If the cat disintegrated, the pieces would blow downstream and could restrict the exhaust flow through the muffler.
  5. TEDDZ
    TEDDZ New Member
    Dec 10, 2017
    3
    1
    The exhaust was taken off and emptied and 3 hands full of material came out of the exhaust. The material was trapped by the third catalytic converter. I reinstalled the exhaust and normal operation was restored and it passed emissions.
    ImperialCrown likes this.
