2006 Chrysler Sebring Convertible 2.7L slight oil leak
Discussion in '200, Avenger/Sebring, Cirrus/Stratus/Breeze' started by bobisnext2, Aug 3, 2017.
  1. bobisnext2
    bobisnext2 Active Member
    Jun 6, 2010
    30
    Hi:
    I have a 2006 Chrysler Sebring Convertible 2.7L with 96K miles. I have noticed for several months that I have had to add a quart of oil or so between 3000 mile oil changes.
    Last week I had my oil changed and was told I had an oil leak. ( I havent noticed any oil on the ground as of yet, so the leak may be slight.
    Are oil leaks at 96K common on this engine? Is there a common cause?
    Thanks!
    bob
  2. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    12,226
    1,718
    Losing a quart every 3,000 miles is considered to within normal parameters.
    Did the shop indicate where the oil leak was? I've never had a 2.7L so I can't comment on the specifics concerning that engine concerning oil leaks. I would suggest cleaning the engine carefully, then watch for oil stains. The problem with small or slight leaks is the oil often gets blown away by the air when the vehicle is at speed and any tell tale stain is hard to spot. Areas to watch would be the head gasket, valve cover gasket, PCV line, oil pan gasket.
    valiant67 likes this.
  3. valiant67
    31,972
    11,545
    I'll add one more common leak point: the oil pressure sending unit. I've never had a 2.7 either, but I've had the sending unit leak oil on a few vehicles.
    Doug D likes this.
  4. ImperialCrown
    18,335
    2,701
    It's strange that they would call your attention to an oil leak, but not tell you where it is or how much to fix it. Did that information not make it to your copy of the work order?
    You need to find out where it is leaking first.
  5. bobisnext2
    Jun 6, 2010
    30
    the shop just told me about the oil leak during an oil change, and said I could make an appointment to get it degreased and inspected
  6. kcapri13
    kcapri13 Active Member
    May 4, 2004
    33
    One spot I have found is common is the oil pan gasket, I had to do mine on my 2004 Sebring 2.7 last year. There are quite a few y-tube videos on the repair
  7. Gerry G
    Gerry G Well-Known Member
    Mar 7, 2003
    1,004
    96
    I do not know if your oil leak and oil consumption are related. I would suggest replacing the PCV valve (with a dealer part) to see if that does not lessen your oil consumption. I was at 1 quart every 2,000 miles, replaced the PCV and am under 1 qt every 5,000 miles (yes I use synthetic and I change every 7,000 to 8,000 miles).
    Yes, I have oil wetness on the pan. Since I am not seeing any drips on the floor, I am not going to chase it. I have 150,000 on an '04
  8. ImperialCrown
    18,335
    2,701
    I have seen the rubber PCV hoses rot and soften from oil exposure and suck flat. This will stop PCV action. Check that as well.
    I have replaced many leaking oil pressure sender switches as well. Diagnosis first.
