2006 Pacifica liftgate
Discussion in 'Minivans · Pacifica' started by rustoleumm, Jan 12, 2018.
  1. rustoleumm
    rustoleumm New Member
    Dec 31, 2017
    3
    I bought a used 2006 Pacifica base model without power liftgate. I cannot get the rear liftgate to open without using the inside emergency opening lever. Any suggestions? All the other doors work with the new remote key. The BCM or some other module has been replaced as mileage was 99k a few years ago and now reads 77K.
    Thanks
    18,344
    2,703
    Welcome to Allpar. This could be an electrical or mechanical issue. Follow the liftgate fails to release-without power liftgate 'possible causes' and diagnostics beginning on p. 691 here:
    http://oskin.ru/pub/chrysler-dodge/...s/2004_CS_Pacifica/18636-cs-body_sgmldiag.pdf
    It could be the handle switch, latch motor, wiring, grounds or BCM. Liftgate connector pinouts/wire colors are shown on p. 1055. BCM connector pinouts are shown on p. 1019-1021. A simplified wiring diagram is shown on p. 1097.
    Non-PLG = without Power Lift Gate.
  3. rustoleumm
    Dec 31, 2017
    3
    Thanks I'll give it a try
  4. rustoleumm
    Dec 31, 2017
    3
    ImperialCrown I ran thru the the diagnosis and it appears that it is the BCMis the problem, but the manual advises against replacing the BCM. If I replace it what are the potential issues?
    Thanks
  5. ImperialCrown
    18,344
    2,703
    A major potential issue is your vehicle inheriting the configuration of the vehicle that a used or unknown BCM came out of. We are advised against swapping modules between vehicles, even if just for diagnostic purposes.
    Once the foreign module 'shakes hands' on the communications bus on your vehicle, your vehicle could become 'that' vehicle.
    In cases of factory alarm and SKIM security key options, this could render a chronic no-start or start/stall situation.
    In these cases, both the PCM and BCM would be 'infected' and require replacement with fresh unwritten modules. Then they would have to be initialized and configured at the dealer to become your vehicle.
    There is no way at the dealer level to reset or erase this new, learned configuration. If your vehicle doesn't have the factory VTSS alarm system, don't plug one in that does.
    There may be online vendors who will send you a pre-configured BCM according to your VIN, but I have had no experience in dealing with them. The best advice is not to just plug in an unknown module.
