2006 PT Severe oil leakage
Discussion in 'PT Cruiser' started by HEMI-Joe, Dec 17, 2017.
  1. HEMI-Joe
    HEMI-Joe Member
    Sep 16, 2015
    4
    What the usual culprit causing severe oil leakage ?.
    After driving it, I park it, and a puddle developes almost immediately, the size of 12" round.
    Oil filter tight, not leaking from oil pan or plug.
    Most usual ?? Seems like coming from plastic timing cover at bottom, then covers the splash then the ground.
    Crankshaft Position Sensor, Oil Pressure Sensor ??
    Any help appreciated. Thanks, HEMI-Joe
  2. Bob Lincoln
    Jul 10, 2002
    29,939
    3,325
    Oil seal has blown out, either at the crankshaft or camshaft. Timing belt will be soaked and need replacement, too.
    peterjon1 likes this.
  3. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,823
    470
    I agree with Bob. The leak is on the wrong side of the engine to be the OPS. Unless you're a DIY mechanic, this is going to be an expensive repair. Timing belt jobs on the PT's around here run from about $1,000 to $1,500. I talked to a guy a couple of months ago that has a very nice customized PT that told me he just paid $1,500 to get his timing belt, water pump and center motor mount replaced. YIKES!
  4. peterjon1
    peterjon1 Well-Known Member
    Aug 14, 2004
    1,121
    81
    Well, my 2.4 Stratus died because of the oil seal. Caused by the thrust washer failing, allowing the crank to move back and forth. A lot. Don't be surprised if your engine is toast. I hope you have caught it in time to avoid that catastrophe.
