AF: 2008 Patriot 2.4L Manuel Trans No Start | Allpar Forums
Discussion in 'Compacts: Renegade, Patriot, Compass, Caliber' started by stroudtom, Feb 14, 2014.
  1. stroudtom
    Jun 26, 2012
    366
    92
    Hi, wife as above vehicle that was parked outside in mid 20 deg temps. She inserts key and motor rotates but does not fire. She tries several times with no results. After 10 mins of this she tries gas pedal movement and motor hits a few times then starts and runs fine. Vehicle has around 80k miles as well. Anybody have experience with this problem before.
    Thanks in advance.
    Tom
  2. Bob Lincoln
    Jul 10, 2002
    31,828
    5,140
  3. stroudtom
    Jun 26, 2012
    366
    92
    Yep, fault code check is next when she gets in for lunch. Thanks for the link.
  4. ImperialCrown
    ImperialCrown Moderator
    21,113
    4,300
    No TSB's or factory STAR cases on cold hard start.
    There have been some PCM software updates since new, but none really address any hard start issues.
    How are the spark plugs? These have a 32,000 mile (50,000 km) change interval. They are not platinum.
    Use the factory recommended NGK ZFR5F-11 for best results.
  5. stroudtom
    Jun 26, 2012
    366
    92
    She checked fault codes and there are none. Plugs are past 30k miles so I'll go there on new ones but I've seen 50k plugs with a large gap running so smooth you'd never now it. "No TSB's or factory STAR cases on cold hard start.", that's what I wanted to know. Thanks Imperial.
