AF: 2009 Ram 1500 Transmission Oil/Filter change | Allpar Forums
Discussion in 'Repairs, Maintenance, Help' started by djsamuel, Jun 29, 2020.
  1. djsamuel
    Sep 10, 2007
    2,956
    887
    I am looking to drop the pan and change the transmission filters on the 545RFE 5 speed transmission. Does anyone know how many quarts of ATF+4 I need to replace what I drain? A search online looks like I need 8 quarts but I want to make sure. Thanks.
  2. bguy
    bguy Well-Known Member
    Dec 9, 2007
    1,769
    165
    Have 8 on hand.
    Buy filter kit with a pan gasket. Use dry whichever one you get. The holes in the gasket are made such that they hold the bolts in place during assembly. No need to glue it in place. I have had 100% success with both cork and rubber gaskets.
    djsamuel likes this.
  3. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    4,390
    1,048
    I would measure the amount of fluid that drains from the transmission after pan removal. Put that exact same amount of fresh fluid into the transmission. Run and then check fluid level and adjust accordingly.
    Link discusses replacement fluid quantity.
    5-45RFE Fluid change capacity (at https://www.dodgetalk.com/threads/5-45rfe-fluid-change-capacity.131547/#:~:text=The%20545RFE%20tranny%20hold%20a,(5.5%20qts)%20for%202X4 ).
  4. DC-93
    DC-93 Well-Known Member
    May 1, 2014
    3,005
    1,905
    Does the converter have a drain plug?
  5. KOG
    KOG KOG
    Jan 8, 2003
    6,865
    401
    There hasn't been a drain on a converter for many decades.
