2013 Dodge Journey dead battery
Discussion in 'Dodge Journey' started by nanacanjo, Oct 28, 2014.
  1. nanacanjo
    nanacanjo New Member
    Oct 28, 2014
    7
    Less than 14,000 miles. Perfect for about 15 months. Love this car but something is draining the battery. Fourth time towed into dealer. Is anyone else having this problem
    18,233
    2,660
    Welcome to Allpar. An intermittent battery draw can be difficult and frustrating to find. It almost has to be confirmed while it is occurring, otherwise everything appears to be normal.
    The dealer should be able to access TSB's on this problem. What has the dealer done so far?
  3. John Wood
    John Wood Well-Known Member
    Nov 13, 2002
    11,078
    153
    Was anything left in the power outlet (GPS cord, Cell phone charger...). One of my outlets on the minivan is set up to be energized all the time, so I need to be careful not to leave a charger in there for a long time.
  4. Jeff2KPatriotBlue
    Jeff2KPatriotBlue Radioactive
    Aug 6, 2002
    5,346
    46
    My 2010 has a "feature" that turns on the interior lights when the key fob gets close.... but my key rack in my house was near the limit for this function, so it would turn them on and off quite randomly.
    Fortunately, this feature can be disabled... check your owner's manual for details.
    Cornupenuria likes this.
  5. ImperialCrown
    18,233
    2,660
  6. nanacanjo
    Oct 28, 2014
    7
    They have replaced the battery twice and charged it twice. I believe they are working with Chrysler and their technical support bulletins.
  7. nanacanjo
    Oct 28, 2014
    7
    Seldom even use the charger and very careful to not leave anything plugged in
  8. nanacanjo
    Oct 28, 2014
    7
    I believe they updated the software on the first time it was towed in. Nothing seems to be off on their diagnostic tests. Car runs fine then the next morning will not start. Almost always a totally dead battery. Car is driven pretty much every day
  9. nanacanjo
    Oct 28, 2014
    7
    I had read this in another forum. Key rack at least 30 feet from vehicle. However, just in case I moved it to the back bedroom
  10. ImperialCrown
    18,233
    2,660
    Something is either staying on or a module is staying awake. IOD (ignition off draw) should be a small amount to keep memories and listening for an RKE signal alive.
    I should be in the order of ~50-100 mA.
    I use a small sidemarker bulb in series with a battery terminal after shutting the car off. It may glow dimly for awhile. That is normal.
    If it glows brighter than a dull orange, the battery may be dead by morning. In this mode, the dealer should be able to go in and rule out circuits one by one by disconnecting them until draw is reduced to an acceptable amount.
    When you find the circuit that is drawing excessive current, you have probably found your answer.
    Hankster and Doug D like this.
  11. nanacanjo
    Oct 28, 2014
    7
    I appreciate the reply, I am waiting for further instructions from Chrysler Customer Care, If you OK with you , I will forward this to the service manager.
  12. nanacanjo
    Oct 28, 2014
    7
    Thanks for the response. I am waiting for a response from Chrysler Customer Care. If it is OK with you, I will forward this to the service manager at my dealership.
  13. ImperialCrown
    18,233
    2,660
    Best of luck to you and the dealer. Again, if this is 'intermittent' and the battery draw problem isn't there, then everything will appear to be working correctly. They have to catch it while it is acting up or try to 'tease' it into acting up.
  14. paullybob
    paullybob Well-Known Member
    Mar 22, 2006
    438
    48
    Sounds similar to an issue with the 2009-2011 Dodge Charger with a bad SKREEM module and door handles combining to keep the IOD active for long periods of time. I'll see if I can track the RRT down and PM you with it.
  15. gforce2002
    gforce2002 Well-Known Member
    Oct 31, 2003
    1,417
    308
    This sounds like a similar problem to one my 2011 Journey had - working fine for days/weeks and then BAM, dead battery. They finally replaced some controller module (wish I could remember what one), but that finally fixed it. As paullybob stated above, it kept in active state for long period of time, draining the battery.
  16. Cornupenuria
    Cornupenuria Active Member
    May 23, 2013
    746
    153
    I can remember somebody having a defective CMOS chip in the clock circuit in the radio drain the battery overnight.
  17. paullybob
    Mar 22, 2006
    438
    48
    Here's the RRT you need to look for but I remind everyone that theses issues are usually VIN specific so it may or may not be for your particular vehicle. Search for this RRT information:
    Chrysler RRT 11-082 for 2011 Journey/Charger/300
  18. paullybob
    Mar 22, 2006
    438
    48
    As an add-on to this conversation, I just installed a battery warmer to my 2013 last weekend. The battery, like several other Chrysler products, resides in the driver side fender well. I cleaned up the battery connections and emptied out all the gravel and dirt from the battery tray area, installing the blanket was a cinch and routing the electric cord was painless. Hopefully, this keeps my battery temperature about zero or so on those coldest nights and let me get full juice for starting this winter.
    Only note I'd add is the negative terminal on my Journey has a cast zinc sensor/battery terminal that would be prone to damage by overtighteneing so please be careful if you come upon this particular issue.
  19. mcubillo
    mcubillo New Member
    Dec 15, 2004
    25
    I've had to replace the battery twice in my '09 Journey. The problems start with some intermittent non-start where only a click happens when the key is turned and then progressively get worse. Everything seems OK, then battery completely drained.
    The new battery takes care of all those issues. Unfortunately the battery life has been very short.
  20. paullybob
    Mar 22, 2006
    438
    48
    UPDATE!!!! After installing the battery warmer (still on the OE battery BTW) and undergoing several cold nights up here, I can safely and gladly report that the battery warmer is the way to go!! Sure, the Journey still squeals like a stuck pig on start up and the power steering pump groans like its gonna explode but they all do right? The Journey turns over with ease, all the electronics fire up first shot in the morning (i.e. no more flickering or blank Uconnect screen) and there are no more unexplained audio alerts for whatever.
    This is just the beginning of our winter here, I'll post up as the weather gets even colder for longer periods of time to let you know if this is a permanent fix.
    Happy New Year everyone!!!!!
    floridaman2013 likes this.
