2016 caravan. hood latch
Discussion in 'Minivans · Pacifica' started by theKING, Dec 31, 2017.
  1. theKING
    theKING Active Member
    Nov 24, 2005
    75
    7
    hood latch mounted above radiator is loose allowing hood to shake... tightened up bolts.. anyone know if there are supposed to be any type of nuts on backside? currently these bolts just thread into the cross bar with no nuts on back..
    18,326
    2,697
  3. theKING
    Nov 24, 2005
    75
    7
    hmm.. they must have stripped them during assembly.. its a 2016 and tjey just wont stay tight.
  4. ImperialCrown
    18,326
    2,697
    Are they sticking out the back of the tie bar far enough to get conventional lock washers and nuts on them? Or is this still under the 3/36 warranty?
  5. UN4GTBL
    Jan 7, 2006
    8,126
    2,842
    Could you add locktite to the bolts if there is enough material there?
  6. theKING
    Nov 24, 2005
    75
    7
    bolts were much longer than needed. Added lock washers and nuts. Factory stripped them.
