2016 Grand Caravan RT Traction control and ABS lights on
Discussion in 'Minivans · Pacifica' started by theKING, Dec 27, 2017.
  1. theKING
    theKING Active Member
    Nov 24, 2005
    76
    7
    van just turned 21,000 miles. First day in bad weather the ABS and traction control stop working. I suspect a wheel sensor but really have no idea. The traction control button does nothing. The van has seen about 12 driving cycles now and if it was something that would reset itself i think it would have by now... suggestions? unplug battery?
    18,327
    2,697
    Stop at an auto parts store and see if they have a customer-use OBDII scan tool that can read ABS codes?
    Begin diagnosis with the fault code. If the fault code doesn't seem real (like a one-time wheel spin or skid), then erase it and watch for a re-occurrence.
    Doug D likes this.
