2016 Jeep Cherokee: ZF 9 speed issues over? any other problems?
Discussion in 'Cherokee, Liberty, Nitro' started by Impending, Feb 14, 2016.
2016 reliability: Buy or Not?
Poll closed Dec 14, 2016.
  1. Buy
    100.0%
  2. Run
    0 vote(s)
    0.0%
  1. Impending
    Impending New Member
    Feb 14, 2016
    5
    I really like the way they drive. I have one specced, but the deeper I look at the reliability issues this car has had the more I get spooked. Any advice would be appreciated.
    • 3.25 Axle Ratio
    • 700 Amp Maintenance Free Battery
    • 8.4' Touchscreen Display
    • Active Drive II Badge
    • Air Conditioning ATC w/Dual Zone Control
    • Auxiliary Transmission Oil Cooler
    • Comfort/Convenience Group
    • Electronic Range Select
    • Engine Oil Cooler
    • Engine: 3.2L V6 24V VVT w/ESS
    • GPS Antenna Input
    • Hill Descent Control
    • Jeep Active Drive II
    • Jeep Black Gloss Badging
    • Off Road Suspension
    • Passive Entry/Keyless Go
    • Power 4-Way Driver Lumbar Adjust
    • Power 8-Way Driver Seat
    • Power Front/Fixed Rear Full Sunroof
    • Remote Proximity Keyless Entry
    • Stop-Start Multiple VSM System
    • Transmission: 9-Speed 948TE Automatic 2 Speed PTU
  2. Mopar392
    Mopar392 Well-Known Member
    Mar 28, 2009
    1,648
    461
    A question, Do you really need a car now or can you wait till the fall?
  3. valiant67
    31,997
    11,569
    My 2015 Cherokee (2.4 FWD 9 speed) was flawless, other than a minor issue with the grill shutters.
    I traded it because I needed a bigger vehicle to tow with.
  4. Impending
    Feb 14, 2016
    5
    No real time scale. Just wanted to get the $3000 incentive. I can wait, do you think they'll ever be trouble free.
    The closer I get to buying it the more bad news I find online. Rental fleet manager said to 'stay away' from 15 Cherokees like the plague. I had a rental 2.4, it was a riot. I love the car, I just need a reliable car too. Thanks again for all comments.
  5. humdrum
    humdrum Well-Known Member
    Nov 4, 2010
    802
    692
    My 2014 Cherokee Latitude with the 9 speed and V6 has been flawless over 19,000 +miles. plenty of punch, stability and ride characteristics. A joy to drive and easy to live with once you realize by virtue of the 9 speed you have more gears to deal with. It is now second nature and great in winter driving. I have the Active Drive II. I love it for longer trips especially, good mileage. Good in city driving too.
  6. Impending
    Feb 14, 2016
    5
    Does the active drive II raise the suspension at all? When you add that upgrade it says "off road suspension". I love the way it drives (including the 9 speed). I can't think of another car that would be this fun to drive under $50k.
  7. Impending
    Feb 14, 2016
    5
    Why?
  8. Mopar392
    Mar 28, 2009
    1,648
    461
  9. Impending
    Feb 14, 2016
    5
    Kinda a serious question, I might buy this weekend.
  10. Mopar392
    Mar 28, 2009
    1,648
    461
    The update is good
  11. humdrum
    Nov 4, 2010
    802
    692
    I had mine parked right next to a Cherokee Sport FWD. Yes, My car was taller. I can't tell you how much taller, but you could plainly see the difference.
  12. gforce2002
    gforce2002 Well-Known Member
    Oct 31, 2003
    1,431
    325
    I'm closing in on 30K kms with my 2.4L '15 Cherokee Trailhawk, and the transmission has been flawless. A joy to drive really, and I prefer it over practically any other automatic that I've ever driven.
    Dave Z likes this.
  13. 2012srtchallenger
    Supporter
    Jan 27, 2013
    93
    60
    I have close to 5,000 miles on my Trailhawk, not even a hiccup, is great to drive, quiet, good gas mileage. have v6 engine. have driven in snowy weather don't know roads are slick.
    gforce2002 and ImperialCrown like this.
  14. 2017 Rich
    2017 Rich Member
    Aug 1, 2017
    1
    This really isn't about the 2016 but if my with the 2017 Cherokee Sport is an indicator I would say nothing has changed. I bought the 2017 on July 20th. By the time I got done with all of the Paperwork it was close to 6:00 PM and I drove it home (aprox. 8 miles) from the dealer. The shifts in the lower gears were clunking sometimes and sometimes not. The next day I put about 20 miles on it in mostly stop and go traffic same result. Aprox. 5 miles from home the check engine light came on. I got home and shifted in to reverse and nothing happened, shifted into drive with same result. Shut down and set for about 5 mins. turned the ignition back on and by revving the engine to about 3000 RPM got the thing to move so I could pull up onto my front lawn facing out, unloaded groceries (98F) then restarted and checked, still no reverse but pulled out in drive and headed back to dealer. At second stop light had to rev to 3000 again to get moving. Pulled into dealership about 3:00 PM, July 21st. Less than 24 hours and 50 miles was told I needed a new transmission. I would say that the 9 speeds still suck.
  15. 1999 White C5 Coupe
    1999 White C5 Coupe Well-Known Member
    Jul 11, 2006
    215
    56
    Did you test drive the vehicle prior to purchase? If so, was the transmission operating smoothly then?
