AF: 2017 Pacifica tpms auto relearn question | Allpar Forums
Discussion in 'Repairs, Maintenance, Help' started by sickboy, Sep 23, 2020.
  1. sickboy
    sickboy Well-Known Member
    Feb 28, 2011
    941
    919
    I have a 17 Pacifica and want to get a separate set of wheels and tires for winter. My other mopars will recognize the alternate sensors and Relearn without using a scan tool of any sort. Will the Pacifica do the same? I’d rather not buy a scan tool.
  2. Best Answer:
    Post #2 by AllanC, Sep 24, 2020
  3. AllanC
    AllanC Well-Known Member
    Jan 6, 2003
    4,575
    1,154
    At this Chrysler Pacifica forum follow the discussion about TPMS for Pacifica models. The discussion seems to indicate that Pacifica has a different model of TPMS device that is different from what Chrysler has used in the past.
    I would let the vehicle sit unused, ignition key out of vehicle overnight. Then drive the vehicle above 40 mph for a longer time period and see if the system will recognize the new sensors. If that does not work then you probably will have to get a shop (any tire shop) to reset and relearn the sensors.
    TPMS ?? reset ?? (at https://www.pacificaforums.com/threads/tpms-reset.3874/ )
    ImperialCrown likes this.
  4. sickboy
    Feb 28, 2011
    941
    919
    Thanks
    Seems the poster had a good result in the end. Make sure I get the correct sensor. I will get a full set of winter wheels. I will also post my results in case it helps anyone else
