AF: 2019 Compass Brakes. | Allpar Forums
Discussion in 'Compacts: Renegade, Patriot, Compass, Caliber' started by AYOUNGSTEIN, May 30, 2019.
  1. AYOUNGSTEIN
    AYOUNGSTEIN Active Member
    Dec 4, 2002
    65
    I replaced my 2012 Compass with a 2019 .
    I noticed the brakes on the new one are extremely sensitive and grabby.
    When I bring it in for it’s first oil change I’m going to mention it.
    Does anyone know if there is an adjustment available?
  2. link3721
    Oct 18, 2012
    1,317
    1,148
    Could be the difference between old worn brakes and brand new brakes. Not sure they'd be able to tweak them much.
  3. Bob Lincoln
    Jul 10, 2002
    31,831
    5,141
    Sometimes this means the pads are contaminated.
  4. ImperialCrown
    ImperialCrown Moderator
    21,117
    4,302
  5. gforce2002
    gforce2002 Well-Known Member
    Oct 31, 2003
    2,106
    1,374
    Every new Compass is like this (including mine). Pretty much every review of them mentions it. And no, it doesn't get better, you just get somewhat used to it.
    It's one of the things other than the lack of low range, in my opinion, that makes it quite unsuitable for offroad use. The brakes are very hard to modulate at low speed between "no brake" and "full stop". Trying to go slowly over a rocky area under control is almost impossible. And again, the lack of low range means there's no crawling speed without using the brake.
  6. Tin Man 2
    Tin Man 2 Active Member
    Dec 14, 2017
    1,057
    1,501
    Our new Compass is sensitive also, you get used to it.
