2019 Mustang GT500: Forum offers clues about engine, brakes...
Discussion in 'Auto News & Rumors' started by redriderbob, Dec 11, 2017.
  1. redriderbob
    redriderbob Mopar Guru!
    Feb 22, 2004
    10,561
    17,709
    [​IMG]
    Seems like there's an intriguing leak per day over at the Mustang6G forum, which on Monday had posted a photo that seemed to pretty much cinch the existence of a 2018 Bullitt Mustang. Now, the forum has posted what it says are Ford documents and pictures that seem to confirm a supercharged 5.2-liter engine is headed for the 2019 GT500 — no mere Coyote, but the one they call the "Predator."
    Forum member Super Werty posted the first images of this engine, showing the supercharger nestled below the intercooler of the intake manifold.
    A document titled "2020 MY North America Vehicle Program – Engine Oil Requirements" has a footnote that indicates the next GT500 engine gets the Eaton-supercharged cross plane version of Ford's 5.2L engine. We know this because the chart says it will require 5W50 oil.
    An image posted in the thread by Mustang6G member dwalker might show the GT500's brakes, which the forum has previously reported will be massive true two-piece rotors that are larger than those on the GT350. Spy photos have shown 20-inch wheels and massive tires (315s at the rear).
    The GT500 could have output in Dodge Demon territory, with potentially over 800 horsepower, and may have a dual clutch transmission derived from the Ford GT's seven-speed.
    2019 Mustang GT500: Forum offers clues about engine, brakes (at https://www.autoblog.com/2017/12/11/2019-mustang-gt500-forum-offers-clues-about-engine-brakes/?hcid=ab-around-ab-tile-1 )
  2. mopar22
    mopar22 Well-Known Member
    Sep 22, 2010
    1,326
    522
    If it has output near demon does that mean dodge will be updating there hellcat before the new cars comes out then an even bigger bump once those are out?
  3. tomaz
    tomaz Well-Known Member
    May 13, 2010
    1,769
    681
    NO it will just mean there will be more Mustangs plowing into crowds
    wtxiceman, GasAxe and Mastertech63 like this.
  4. mopar22
    Sep 22, 2010
    1,326
    522
    This one would be too expensive for th average customer so you wouldn’t see that
  5. redriderbob
    Feb 22, 2004
    10,561
    17,709
    HELLCAT get minor power boost for Drag Pack package for 2019.... and I don't mean the NHRA Mopar factory car either.
    wtxiceman likes this.
  6. mopar22
    Sep 22, 2010
    1,326
    522
    Will in be enough to over shadow this or will the next cars/hellcat engine generation be more inline to compete with this engine/car?
  7. redriderbob
    Feb 22, 2004
    10,561
    17,709
    6.2L HELLCAT is here to stay for long while. Don't expect 100 more horsepower if that's what your saying.
  8. mopar22
    Sep 22, 2010
    1,326
    522
    Just any amount of power to compete with the next ford/chevy highend engines
  9. redriderbob
    Feb 22, 2004
    10,561
    17,709
    Up until the LT5 ZR1 engine, no one broke 700 horsepower but Dodge... remember Demon is still the top dog.
    Alonzo Del Real likes this.
  10. mopar22
    Sep 22, 2010
    1,326
    522
    It might be the top dog but people are going to forget/not care if another car comes out with similar numbers and mass produced unlike the demons
  11. redriderbob
    Feb 22, 2004
    10,561
    17,709
    If you say so...
  12. Muther
    Muther Well-Known Member
    Mar 23, 2012
    3,648
    3,182
    The Chevies and Ford’s don’t have enough beef in their castings to reliably get Demon power. They will for sure have to update their castings to get there. Just like Dodge had to do with Hellcat and Demon and Hellcat Power.
    Either that, or put up with heat soak, and blown engines.
    I suspect the new Vette engine and the upcoming GT500 blocks are new castings.
  13. Mopar392
    Mopar392 Well-Known Member
    Mar 28, 2009
    1,646
    460
    What surprises me is that Ford decided to use a high revving with Flat plane and add a supercharger.
    The old GT500 5.8L was prone to heat.
    I don't follow Stang that much except for laugh, but aren't the ones hitting the crowd come with the solid rear suspension?
  14. Zachary
    Zachary Active Member
    Apr 6, 2017
    42
    54
    As far as the Corvette ZR1, it is the same casting/engine as the "normal" 6.2L Vortec used in everything from full-size trucks to the Camaro SS/ZR1/1LE to the SS to the Corvette.
  15. TheViking
    TheViking Active Member
    Mar 13, 2015
    19
    24
    The consensus is Ford is going to utilize a standard cross plane crank in the new GT500, not the flat plane. The Coyote motor was also prone to high oil temps, especially under high RPM use for extended periods, so I'm guessing a considerable amount of engineering will go into addressing this issue. Many Ford fans were surprised/disappointed that Ford didn't go with a turbo on the motor, especially in light of the whole "EcoBoost" theme. Maybe some here can shed some light on why manufactures are so resistant to adopting turbos at this level.
    Regarding the SRA cars, all 1979-2004 Mustangs used a 4 link setup affectionately called the Quadrabind. As you might deduce, it was horrible setup only made worse by most poorly engineered aftermarket components and high horsepower levels. From 2005-2014 the SRA was retained but Ford moved to a 3-link setup which removed most of the bind issues and along with the PHB finally gave the car a semi-competent rear suspension. Unfortunately if the 3-link cars are lowered any significant amount (and most kids do) then the LCA's are no longer parallel to the ground, and you wind up with unfavorable instant-center and anti-squat geometry. Or, in other words, you loose a good deal of traction and overall handling suffers as well. So add more power on an already nose-heavy car, along with an unskilled driver, and you get the expected results.
    All that said, I've rented a Skat Pack Challenger several times with the crappy 245 series all season tires. I've never driven anything else quite so willing to hang it's tail out at the slightest provocation of throttle. I will say it's very progressive and well controlled, which makes it an awesome hooligan mobile :) Also very appreciative that some rental companies apparently still don't monitor there customers driving habits.
    GasAxe likes this.
  16. Mopar392
    Mar 28, 2009
    1,646
    460
    I know what you mean.
  17. scatpack_69
    scatpack_69 Active Member
    Feb 5, 2013
    171
    169
    Stupidity follows Mustangs in general, be they base V8 or high end.
    Uh.....no. It's ok to be wrong, and you're making a killing at it here...
    Demon will NEVER be forgotten. Period.
  18. mopar22
    Sep 22, 2010
    1,326
    522
    Stupidity follows any v8 make but it can only follow up to a certain price range till that group gets way smaller, about 40-50k is when that starts dwindling.
    When a car with similar numbers comes out in the same price range it will be forgotten. It happens with every brand and make in any price category. It’s okay that’s you're wrong about that, I’ll forgive you for trying
  19. wtxiceman
    wtxiceman Well-Known Member
    Aug 30, 2009
    649
    561
    I've already replaced mine with some 275/40. Much better
  20. Mopar392
    Mar 28, 2009
    1,646
    460
    I do plan to replace the stock wheels and tires with wider ones. But right now I'm really on a tight budget..
