AF: 392 charger on the tow truck | Allpar Forums
Discussion in 'New Challenger, 300, Magnum, Charger' started by Panterasr9, Aug 15, 2019.
  1. Panterasr9
    Panterasr9 Active Member
    Aug 30, 2018
    232
    173
    Just had a tow in to the shop it's a really nice 392 charger he said it died while driving and won't restart I will keep this updated as we are working on it should be interesting.
  2. Panterasr9
    Aug 30, 2018
    232
    173
    Codes are P1217 Active exhaust valve 1 performance,u0401 implausible data from ecm,p P2172 high airflow/vacuum leak detected. Vehicle will not start or run, feel free to take a crack at it!
  3. ImperialCrown
    ImperialCrown Moderator
    20,957
    4,165
    Compression sound OK and even while cranking?
  4. Panterasr9
    Aug 30, 2018
    232
    173
    Well went out to try to start it, no crank just nothing, gauges sweep has plenty of battery power but just does nothing.
  5. Panterasr9
    Aug 30, 2018
    232
    173
    Technician is leaning towards a locked up motor at this point that would be shocking! About to find out oil level is good.
  6. Panterasr9
    Aug 30, 2018
    232
    173
    Ok engine is locked up we have a locked up 6.4 liter fortunately he is still under warranty from Dodge. Oil level was good and up to date.
    Has anyone seen this before?
  7. ImperialCrown
    20,957
    4,165
    If it is under powertrain warranty, I wouldn't touch it. Get it to a dealer.
    A valve (#1 exhaust code?) may have dropped or broke and punched a hole in the #1 piston (high airflow/vacuum leak code?)?
  8. AHBGuru
    AHBGuru Active Member
    Mar 22, 2015
    485
    333
    Makes me wonder what modifications were done ...
  9. Panterasr9
    Aug 30, 2018
    232
    173
    Looked bone stock and we advised him to take it to the dealer. It was a young kid driving so who knows what he did to it.
  10. DC-93
    DC-93 Well-Known Member
    May 1, 2014
    2,927
    1,809
    Too young to know he should have taken it the dealer first!
  11. Ed Brock
    Ed Brock Member
    Oct 18, 2019
    23
    9
    I agree with you on all comments.
    Ed
  12. Shane Estabrooks
    Dec 9, 2014
    871
    628
    Sounds like you dropped some lifters... I have a 392 in my Ram 2500, and after the code from cylinder 8 misfire.. start doing research. For me the coil needs replacing but this sounds like the lifters carved out a grove in the cam ... Failure.
