$40 for an air filter? really?
Discussion in 'Dodge Journey' started by cjben, Mar 23, 2014.
  1. ImperialCrown
    18,231
    2,660
    Filter life varies so widely that I only go by a visual inspection and not by a mileage interval.
  2. DC-93
    DC-93 Active Member
    May 1, 2014
    1,626
    802
    Then, wait until it's totally gunked up. I mean you can't see any light at all. You'd be close to the max life for that OEM MoPar filter !
  3. Dave Z
    Dave Z It's me, Dave
    Staff Member Supporter
    Jan 23, 2001
    32,221
    14,728
    What visual criteria do you use, IC?
  4. ImperialCrown
    18,231
    2,660
    I basically see how darkened the filter paper is. However, this can be misleading in areas with road salt dust or other lighter colored dusts. I also hold a shop light under the filter and I should be able to see light.
    Tapping the filter against a bench top will also dislodge trapped debris. If it seems excessive, the filter gets replaced.
  5. Dave Z
    Jan 23, 2001
    32,221
    14,728
    Ah, gotcha. Thanks. It's probably getting near time to check mine. All of them.
  6. phillip123
    phillip123 Member
    Jan 15, 2015
    107
    35
  7. Mopartial
    Mopartial Fits and Finishes
    Mar 6, 2012
    1,095
    859
    If you can't trust a guy with a mullet, who can you trust? :cool:
    #47 Mopartial, Jul 21, 2015
  8. phillip123
    phillip123 Member
    Jan 15, 2015
    107
    35
    Mullets don't lie! :cool:
  9. Dave Z
    Jan 23, 2001
    32,221
    14,728
    How's this relevant?
    Bob Lincoln likes this.
  10. Mr.Source
    Jan 22, 2002
    3,437
    1,462
    I change it every 5k miles.
  11. ImperialCrown
    18,231
    2,660
    It will vary with conditions. Some areas will be dusty and some not.
    The filtering surface area of modern air filters is huge.
    Don't forget the cabin air filter. It is usually out-of-sight, out-of-mind. If you have an interior mounted one (behind the glovebox, etc), lay newspaper down on the floor before pulling it out. I have had some 'dump' large amounts of debris as I've removed them from the HVAC housing.
    Some more expensive CAFs are activated charcoal (gray in color) and HEPA-certified. Febreeze also markets a scented HEPA CAF.
    floridaman2013 likes this.
