46RE NO Lock-up 1991
Discussion in 'Ram, pickups, commercial trucks' started by jase386, Oct 4, 2017.
  1. jase386
    jase386 Member
    Feb 5, 2015
    31
    1
    1991 B350 with 46RE I don't think is going into lock up. Mostly asking today, when should I feel the lock-up engage or does it happen simultaneous with another shift?
    any information on this trans is greatly appreciated, as this is my first dodge. I am used to Ford and GM, both of which I am familiar with shift points and lockup points.
    thanks ahead of time.
    18,146
    2,620
    Any fault codes or 'ck engine' light?
    The torque converter lock-up should feel (or sound) like a 4th-5th shift between 40-50 mph under gentle acceleration.
  3. valiant67
    31,520
    10,621
    First of all: are you sure this is indeed a lockup transmission? From the specs I see there were lockup and non-lockup 4 speed automatics with the 5.2 engine and a non-lockup 4 speed auto with the 5.9 engine.
  4. valiant67
    31,520
    10,621
    I can’t say this is 100% accurate, but from what I read the lighter duty transmission (A500 aka 42RH) is lockup and the heavy duty transmission (A518 aka 46RH) is non-lockup.
    Being a 1991, yours should be an RH transmission, not an RE.
    Bob Lincoln likes this.
  5. jase386
    jase386 Member
    Feb 5, 2015
    31
    1
    No CEL or codes at this time. I just know that I only feel three shifts. 1-2, 2-3, 3-OD
    I think it is the 46RH, got confused with all the articles that led to nowhere. The sticker on the underside of the hood says A518 Lock UP converter. This van does have the 360 5.9.
    Will the lockup feel like a 3-4 shift, and overdrive feel like a 4-5 shift ( I know there is no fifth, just saying FEELS LIKE)
    or is lockup and engaging Overdrive the same movement?
    is there a physical trait of the lockup trans I can look for from under the van like a certain harness, tube, wire, switch etc, that a non lockup wouldn't have?
  6. ImperialCrown
    18,146
    2,620
    Sorry, I misspoke. It should feel like a 4th to 5th upshift. Have you felt lock-up in the van before and now don't feel it?
  7. valiant67
    31,520
    10,621
    I’ve never felt the lockup as strongly with these in my Dodge pickups as compared to the lockup in my parents Ford cars. Sometimes if not for the tach, I wouldn’t notice the lockup.
  8. jase386
    jase386 Member
    Feb 5, 2015
    31
    1
    I bought it well used. Ive never felt lock up in it. I haven't had it long. I just noticed it seems to run really hard on the interstate, and started digging around, then realized it doesn't seem to lock up. Older GM transmissions feel like a 3-4 shift and OD comes in with a 4-5 feel. Ford AOD's drop into 3 and lockup with the same movement. I plan on towing an RV trailer with this van, but it really runs hard over 60mph.
    I only feel the 1-2, 2-3, and 3-4 shifts, that's why I was hoping there would be some easier way to tell by looking at the transmission itself. Just because the hood says its a lockup, doesn't mean the hood or transmission haven't been changed during its previous abusive ownerships.
  9. valiant67
    31,520
    10,621
    There is a way to tell, I just don’t know where to tell you to look. If it is lockup there will be wiring for it, I’m just not sure where on the transmission.
  10. jase386
    jase386 Member
    Feb 5, 2015
    31
    1
    Will a non lockup have wiring also, or less wires? I can try to check today if I have time.
  11. valiant67
    31,520
    10,621
    All of them will have wiring to the neutral safety switch and the OD solenoid at a minimum. The lockup wiring should be separate.
  12. Bob Lincoln
    Jul 10, 2002
    29,842
    3,154
    I have a 92 Dakota with 42RH (A500) transmission behind the 3.9L V-6. I believe the 46RH (A518) of this era will be the same.
    There is a 3-pin connector for the neutral safety switch and backup lights, and another 3-pin connector for the overdrive and lockup. I believe both are on the left side of the tranny, just above the pan, if memory serves. I think the OD/lockup connector is mounted near the left rear corner of the pan, and I know it's mounted vertically, and is a circular plug.
    The lockup engagement is NOT as firm a feel as a shift between any of the other gears, it's just a very, very slight push shortly after the OD engagement. If you have a tachometer, the 3-4 shift at highway speed or just below will show a drop in RPM of about 400-500 RPM, and the lockup engagement will drop no more than another 200 RPM.
    So at highway speed, if you are accelerating around 60-65 mph and it shifts from 3rd into OD, it will drop from about 2600 RPM to 2100 RPM, and drop to 1900 RPM when lockup engages.
    You can also test by pressing the OD lockout switch and driving at moderate speeds, and feeling for the lockup after the 2-3 shift. With OD locked out, the lockup torque converter still engages after the 2-3 shift.
    There is a dual solenoid pack that screws to the right side of the valve body inside the pan that controls the OD and lockup shifts. If the screws come loose, or if the solenoids fail, or if the connector is loose, the default is no 3-4 shift, and no unlock of the torque converter until the 3-2 downshift when slowing.
  13. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    5,496
    431
    If you have a locking converter, you should have a lockout switch. Regular should not have a switch.
  14. Bob Lincoln
    Jul 10, 2002
    29,842
    3,154
    The switch is an OD lockout, it does not lockout the lockup torque converter. When you lock it in 3rd, it still engages the lockup.
  15. jase386
    jase386 Member
    Feb 5, 2015
    31
    1
    i looked underneath today, and found the round 3 wire connector going into the side just above the pan, there is another 2 wire connector going vertically into the top of the housing, above the left rear corner of the pan. and the speed sensor wiring way back on the tail .
  16. ImperialCrown
    18,146
    2,620
    The vertical 2-prong connector would suggest to me an O/D solenoid only. A vertical 3-prong would be the O/D and Lock-up. See figure 21A-2700 for a picture here (item # 3):
    http://oskin.ru/pub/chrysler-dodge/manuals/Chrysler_Service_Parts_Catalog/CD1/81-96/90t.PDF
    The 3-wire connector going into the side just above the pan would likely be the Neutral safety/Reverse lamp switch shown in figure 21A-2200 (item # 23).
    Is this correct? Yours may not have the lock-up feature.
  17. Bob Lincoln
    Jul 10, 2002
    29,842
    3,154
    Sounds like there is no lockup, if it's only a 2-pin connector.
    Page 21A-1700 for the A500 shows two configurations, items 3 and 22, with and without lockup. 3-pin with lockup, 2-pin without.
    The horizontal connector with 3-pins is always neutral safety switch and backup lights (3rd wire is their common 12V, and they each have their own ground), which is present on every automatic since, what, the early 1960s?
    ImperialCrown likes this.
  18. jase386
    jase386 Member
    Feb 5, 2015
    31
    1
    sadly, for me, its only a 2 pin connector. i checked again, with a flash light this time, to make sure. Since i plan on mostly interstate travel with this van, i was hoping for lock-up to calm the rpms down at hwy speed. This thing just roars at 60 and 70. Pulling a 37 foot trailer will, of course, limit my speed to between 60 and 70 anyway. Maybe some exhaust work will calm the noise down, i know the muffler is weak.
    Thanks for all of the help and comments. Being new to Dodge trucks, I will probably be back soon with other questions.
  19. RalphP
    Aug 26, 2014
    93
    29
    Best thing you can do is to get the tail pipe out from under the bed; side or rear exit.
    That works wonders to making it quieter inside the cab.
    I've also added a Dynamat-alike inside my 1988 Dakota; that helps a lot too.
    RwP
  20. ImperialCrown
    18,146
    2,620
    I believe that this is a B-van? Interior insulation helps. The engine cover (doghouse) must be securely fastened to the firewall and floor.
    Many of these came with 4.11 gears in the rear axle. Even with O/D, they would roar above 55 mph.
    Make sure that what you are hearing is engine noise. Drivetrain bearings, wheel-bearings and wind/turbulence noises can 'roar' as well.
