54 Plymouth wheel size
Discussion in 'Other classic cars' started by RedPlymouth, Jul 22, 2017.
  1. RedPlymouth
    RedPlymouth Member
    May 15, 2017
    1
    Hi all,
    I have a 1954 Plymouth Cranbrook P25 series that was built in Adelaide South Australia. It was fully restored when I acquired it & has 16" x 6" wheels and cross-ply tires. Now that the historic registration rules have been relaxed I want to get 15" wheels to fit so I can put radials on to improve the ride & handling (the only 16x6 radials I can get here are light truck tires). I need advice on what 15" wheels I can get that will fit the stud pattern and would be readily available in Adelaide. Second hand would do.
    Thanks, Bob.
  2. Bearhawke
    Bearhawke Things happen for a reason
    Jun 18, 2003
    13,594
    332
    I'm 99% sure that 15" Dodge Phoenix (Ply Fury) wheels would work on your car; same bolt pattern, hub diameter, etc. Other wheels will have the correct bolt pattern (Ford Galaxie, etc) but, the center holes may be different, which can be critical when discussing hub centric weight carrying.
  3. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    5,495
    430
    Ford center hole is smaller.
    Bearhawke likes this.
