64 Chrysler 300 rear brakes
Discussion in 'Other classic cars' started by Gdude40, Nov 26, 2017.
  1. Gdude40
    Gdude40 New Member
    Sep 11, 2017
    9
    4
    Anyone have tips on how to remove rear drums on 64 Chrysler 300 with old style 8 3/4 rearend?
  2. Bob Lincoln
    Jul 10, 2002
    29,879
    3,258
    Wouldn't it be the same as any drum brake? Jack up car, remove wheel, loosen brake adjustment and pull drum?
  3. 68RT
    68RT Well-Known Member
    Aug 8, 2003
    5,512
    440
  4. 68RT
    Aug 8, 2003
    5,512
    440
    This was a 2012 post. Can one of the masters restore it? It will be hard to find one unless you find person active in brakes in the late 60's or before. Best ones were made by OTC and Snap-on.
  5. 68RT
    Aug 8, 2003
    5,512
    440
  6. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    892
    293
    I didn't know there was a "trick" to it. I many cases they haven't been removed for years so they are "frozen" on. I have always used a hammer to hammer them off on a couple realy tough ones had to use a torch to loosen them up.
  7. ImperialCrown
    18,232
    2,660
    The puller is gentler on the wheel bearings than a sledge hammer. Start the nut back onto the axle threads so the puller center screw doesn't mushroom the threaded axle end.
    Also if the drum suddenly releases with some force, it won't pop off and possibly injure you. Wear safety glasses.
    Bearhawke and saltydog like this.
  8. 68RT
    Aug 8, 2003
    5,512
    440
    I always turned the nut over to protect the castle part and give the end of the threads even more protection.
    saltydog and ImperialCrown like this.
  9. Bearhawke
    Bearhawke Things happen for a reason
    Jun 18, 2003
    13,604
    335
    Mopar Tapered Axle Brakes (at http://hotrodsandhemis.com/TaperedAxleBrakes.html )
    71Charger_fan and Bob Lincoln like this.
  10. 71Charger_fan
    71Charger_fan Active Member
    Aug 1, 2014
    267
    172
    Having mushroomed the end of a tapered axle trying to pull a drum, I can say from experience that it's important to have that nut on when cranking on the puller. Since I damaged that axle, I also put a washer between the puller pressure screw and the axle end/nut
    Bearhawke likes this.
