'64 D100 rear axle seal
Discussion in 'Power Wagon' started by gearhead, Jan 27, 2015.
  1. gearhead
    gearhead Well-Known Member
    Oct 22, 2003
    3,314
    5
    I know this forum is for Power Wagons, but I'm guessing some (or most) of you have more experience with the tapered axle 8-3/4" rearends.
    I'm kinda baffled. On my 1964 D100 how does the rear outer wheel seal, seal anything? It doesn't appear to "seal" against anything on it's OD. At least the ones on my truck don't, and the ones that I ordered don't. The outer axle bearing race sits flush with the axle housing flange (where the brake backing plate mounts) so it can't seal to the ID of the housing flange. According to a 1962 Motors Manual that I have the seal is supposed to install in the backing plate (Motors calls it a brake support). None of the seals listed by the parts houses have dimensions that would allow them to work for my truck.
    The ID of the brake backing plate (brake support in Motors Manual terminolology) is 2.505" and the OD of the seal is 2.443". The seal just spins with the axle.
    Any ideas, solutions, or advice?
  2. Volunteer
    Volunteer Well-Known Member
    Jan 16, 2003
    2,577
    41
    Just curious, after many months and no replies, how you made out. Perhaps you posted in another section? thanks.
  3. ImperialCrown
    18,231
    2,660
  4. Volunteer
    Jan 16, 2003
    2,577
    41
    Thanks, 'I C'
