AF: 90 lebaron dome lights stay on at 2 percent | Allpar Forums
Discussion in 'EEK! - Every Extended-K Car' started by neon98rt, Sep 23, 2020.
  1. neon98rt
    neon98rt Well-Known Member
    Feb 18, 2011
    732
    24
    When it is dark out i can still see the LED interior lights on > door, mirror, center console rear. They are on at like 2 percent power with LED lights in them. My guess is that it has been like that a long time but i never could see it with normal bulbs.
    I have removed door switches, still on
    removed dash pod , still on.
    I took out the BCM and sprayed it off but it looked fine. I thought maybe dirt was arching . Still on.
    What am I missing?
  2. voiceofstl
    voiceofstl Well-Known Member
    Jan 15, 2010
    2,407
    1,218
    My front porch light is switched to a old fashion timer switch, when the old light burnt out I replaced it with a LED. When it is off I can tell its still dimly lit. So somehow proberly through that timer switch electricty is leaking to the LED.
  3. Bob Lincoln
    Jul 10, 2002
    31,921
    5,245
    What this indicates is that the electronics allow a small leakage current through, that was undetectable with an incadescent filament, not enough to light it. It shows that the LED is more efficient, and that the electronics used to drive the lights are of an older, inferior design. When I changed all my dash lights in my Daytona and Dakota to LED, the Check Engine and Low Fuel lights glow very, very dimly. But noticeable to the point that my wife called me once, all worried about the Check Engine light being on in the truck.
  4. neon98rt
    Feb 18, 2011
    732
    24
    that is what i was hoping to hear that the wires have power to them. It is odd they do but good news . Now i wonder if my tail lights stay lit just a bit.
