'94 Chrysler LeBaron sedan - auto seat belt delete
Discussion in 'EEK! - Every Extended-K Car' started by goair99, Nov 1, 2017.
  1. goair99
    goair99 Active Member
    Nov 9, 2013
    255
    45
    Has anyone here removed their annoying passenger side automatic seat belt? I stripped out a '93 NY'er Salon interior(seats, carpet, belts and trim) to put in my LeBaron. I could not pass this up because this car has a immaculate interior and I want the upgraded carpet and put the velour seats in my LeBaron.
    Any help would be appreciated!
  2. valiant67
    31,676
    10,950
    Find a pre-1994 LeBaron/Spirit/Acclaim without the automatic passenger belt. Install those parts in your car.
    I think 1994 was the first year that passive passenger side restraints were required, so there should be a large selection of manual passenger seat belts for it. The LeBaron convertible added a passenger air bag. The sedan used the low tech automatic belt.
  3. Bob Lincoln
    Jul 10, 2002
    29,875
    3,253
    What valiant67 said. Don't remove the automatic belt and not install a full working manual system for two reasons:
    1) If you have safety inspection where you live, it will likely fail. Or it will fail in a future location with another owner.
    2) It would be hard to sell in that condition. I would never buy a vehicle that had the restraint system removed or tampered with.
  4. goair99
    Nov 9, 2013
    255
    45
    Ok, well...I assumed that the holes are all there to install the manual belt in the B-pillar. I would reuse the anchor position with the new regular female end from the donor car. These belts are in better shape than my LeBaron's. No inspections in FL.
    ClayBelt40's likes this.
  5. goair99
    Nov 9, 2013
    255
    45
    Off the record???
  6. goair99
    Nov 9, 2013
    255
    45
    Conversion is going well. I got the upgraded carpet installed(same color and is almost brand new). While I had the carpet out I dynamated the entire floor. I was surprised that every hole but one lined up with the old carpet. I installed the nice velour drivers seat using the seat track from the old Le Baron seat. Not sure what to do with the passenger side yet because of the auto seat belt.
