99 Durango ABS/Brake light after 40 mph
Discussion in 'Grand Cherokee, Durango, etc' started by Torque Fiend 78, May 19, 2017.
  1. Torque Fiend 78
    Torque Fiend 78 New Member
    May 17, 2017
    4
    I have an abs and brake light that comes on after you hit 40 mph and let it shift into OD. Cruise doesn't work. Shifts are somewhat erratic too until the lights come on. I'm sure this has been an issue with other Durango's and Dakota's. Any input would be appreciated! :)
    18,220
    2,653
    If the yellow ABS warning light comes on, there is a fault code stored in the ABS module. We need to start with this code as it could be many different things. Is this a RWAL (rear wheel) or 4-wheel ABS system?
    Some auto parts stores have free customer use OBD2/ABS code readers that can read ABS modules. The Advance Auto near me has one.
    Torque Fiend 78 likes this.
  3. AC TC
    AC TC Well-Known Member
    Dec 3, 2004
    2,517
    344
    Usually its the speed sensor in the rear axle thats full of metalparticles...
    Bob Lincoln likes this.
