Alfa Romeo SUV news
Discussion in 'Fiat News & Rumors' started by Willem85, Aug 23, 2015.
  1. npaladin2000
    npaladin2000 LOAD "*",8,1
    Oct 1, 2016
    982
    711
  2. romalerig
    romalerig Well-Known Member
    Mar 31, 2009
    450
    500
    Am I right or not ? :D
  3. MJAB
    MJAB Well-Known Member
    Oct 4, 2013
    2,618
    2,813
    Yes, I converted from CV, but values are different :)
    NAFTA
    Maximum power (SAE net) 209 kW
    Maximum power rpm 5,200
    Maximum torque (SAE net) 306 lb ft (415 Nm)
    Maximum torque in the range 2,000 - 4,800
    Europe 2.0 200 CV and 280 CV versions
    Maximum power (ECE) (kW) 147 206
    Maximum power (ECE) (CV) 200 280
    Maximum power rpm 4500 5250
    Maximum torque (ECE) (Nm) 330 400
    Maximum torque rpm 1750 2250
    romalerig likes this.
  4. Ingvar
    Ingvar Active Member
    Feb 13, 2016
    17
    42
  5. Lampredi
    Lampredi Active Member
    May 16, 2012
    952
    591
    Alfa Romeo should change its name to Jeep Romeo.
  6. page2171
    Apr 28, 2007
    578
    663
    Only when they start making trail rated Alfas. The Stelvio looks to be mall rated, and not really intended to go off road.
    ScramFan likes this.
  7. MJAB
    Oct 4, 2013
    2,618
    2,813
    1951 Alfa Romeo AR51 "Matta" (AR = autoveicolo da ricognizione) with engine from an Alfa Romeo Montreal (V8).
    And this is the one with the original engine (65 HP at 4400 rpm inline 4 cylinders dual overhead cams with dry sump lubrification, hemispherical combustion chamber, cast iron block and aluminium head).
    Civilian version was named AR52.
    ScramFan, quadamage76 and Morty like this.
