All FCA US Brands Improve in Initial Quality
Discussion in 'Mopar News' started by manoli, Jun 21, 2017.
  1. Dave Z
    Dave Z It's me, Dave
    Staff Member Supporter
    Jan 23, 2001
    32,387
    15,054
    Call Chrysler first. If that doesn't work, write to them.
    Auburn Hills did nothing. You didn't give them the chance.
    danbek likes this.
  2. Zagnut27
    Zagnut27 Jeepaholic
    Jan 12, 2015
    2,590
    3,974
    Ugh. What you describe reminds me of my mom's epic battles with Ford and the dealer on our collection of misfit toys in the 1980's and early 90's. She was persistent and it paid off though. It's a shame it has to come to that though....
    It turned us off to Ford completely after that. Saturn treated us much better. Jeep...well...not so much, but better than Ford (hard not to). I didn't take a chance on Ford for 20 or so years until I bought my Mustang. Treating your customers like garbage tends to do that....ya hear me FCA??
  3. UN4GTBL
    Jan 7, 2006
    8,153
    2,865
    40,000km, so less than 25,000 miles. It just squeaked in under the 24mths/40k km wear warranty or whatever you want to call it. (Same warranty that Dodge replaced my clutch under at 9,000km)
    And it was all 4 rotors that were warped, not just the front ones. And not minor warping either. It was scary when you tried to stop from highway speeds. The back ones were even worse than the front ones...
    The replacement rotors lasted for 55,000kms which I guess is better, as we just had them changed, as they were starting to become warped.
    Nice!
    Maybe I should call Chrysler USA next time.
    This is the first vehicle we've had in quite some time with warped rotors. I don't remember any of our previous 7 minivans having such short brake life, nor any of our other FCA vehicles. Same conditions, same drivers too.
    somber likes this.
  4. UN4GTBL
    Jan 7, 2006
    8,153
    2,865
    Not true actually.
    Wear items (wipers, light bulbs, brakes, clutches, etc) are covered for a short period of time. I think it's 2 years max though.
  5. DAGAR
    DAGAR Active Member
    Sep 21, 2014
    1,680
    2,504
    Covered for manufacturer's defect, though, not wear. At 40k it's hard to argue it's not wear.
  6. Chase300
    Chase300 Active Member
    Oct 2, 2012
    990
    775
    Your warped rotor condition most likely could have been corrected by you as typically its from deposits of the pad material on the rotor and not that the rotor has in fact "warped".
    1. Wheels must be torqued to proper specs, not put on with impact guns at who knows what TQ.
    2. Pads and rotors have to be properly bedded and the right pad used for your driving.
    I've found #1 to be the best preventative practice to the warped rotor feel.
    -Warped- Brake Disc and Other Myths (at http://www.stoptech.com/technical-support/technical-white-papers/-warped-brake-disc-and-other-myths )
    ScramFan likes this.
  7. Dave Z
    Jan 23, 2001
    32,387
    15,054
    Write to Chrysler now. Send copies of the bills. They may help out. I've seen it happen.
    UN4GTBL, danbek and dmcdonald like this.
  8. vipergg
    vipergg Well-Known Member
    Apr 8, 2002
    2,387
    535
    Other words they are misrepresenting their quality and warranty claims numbers.
    UN4GTBL, JavelinAMX and aldo90731 like this.
  9. Dave Z
    Jan 23, 2001
    32,387
    15,054
    That's an assumption. Also I notice he didn't say the timeframe. It's assumed to be since the takeover. Could be since 2013. I think I would agree that quality's improved since 2013.
  10. chrisg05
    chrisg05 Well-Known Member
    Mar 10, 2008
    151
    52
    The service departments when preforming warentee claims are under the mercy of FCA to get paid. In order to understand why the service departments have gotten worse is to understand how they make their money. The mechanics usually get flat rate per job. More jobs equates to more money in the mechanics pocket. For example a brake job involves cleaning hub surface, regreasing the slide pins, checking the calipers for wear, resurface the rotors and so on. This takes time. Most if not all the time, the mechanic cuts corners and just slaps on a new rotor and a new set of pads. Puts it all together, pumps them up and moves on to the next job
    Oil changes are the same wAy...a flat rate per change. This happens in all dealers.
    It's all about customer service. You give good service at a good rate with a low percentage of repeat jobs you will get repeat customers
  11. danbek
    danbek Well-Known Member
    Apr 12, 2008
    670
    725
    While I feel for you and your issue, I just don't understand the situation. It is not up to the dealer to honor or not honor warranty work and why have you not gone up the chain?
  12. danbek
    Apr 12, 2008
    670
    725
    12 months/12,000 miles is typical on wear items generally
  13. Bigun426
    Nov 15, 2008
    257
    47
  14. aldo90731
    Jul 6, 2010
    5,998
    9,971
    It will take a cultural revolution to get the executives at FCA to change their mindset and take quality seriously.
    I'll believe it when I see it.
    #194 aldo90731, Aug 6, 2017
    UN4GTBL, iNeon, GasAxe and 1 other person like this.
  15. Dave Z
    Jan 23, 2001
    32,387
    15,054
    If they fill out the forms properly they usually get paid. However would you rather be paid $40/hour or $130/hour?
    Medicare or cash?
    UN4GTBL and wtxiceman like this.
  16. KrisW
    KrisW Active Member
    Jan 8, 2015
    1,194
    2,064
    Is that really the most common method of employing service mechanics?
    In Europe, normal practice is to have a staff of mechanics on salary at the dealership; they earn a fixed wage per week - some weeks are slow, some are busy, but the pay's the same. At very busy periods, additional staff can be hired in, but it's usually on an hourly rate basis, not "per job". All work is billed to the customer as parts plus x hours of labour (an hour costs anywhere from around $30 to about $100, excluding sales taxes, depending on what you drive, and where you live; of course, the mechanic gets nothing like that as salary). Warranty work is costed the same way, but customers don't get the bill, and the dealership doesn't get as good a labor rate.
  17. GasAxe
    GasAxe Well-Known Member
    May 12, 2008
    4,601
    5,512
    What I've heard from a few mechanics is when they worked at a dealer, the standard pay is a low salary then you can earn "bonus" money for specialized "per job" work you are trained for. The general consensus was even with the bonus money, you aren't recouping the costs for your tools easily and the time allotted to do the work keeps getting cut so you end up working for free a lot of the time.
    UN4GTBL likes this.
  18. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    12,234
    1,725
    To elaborate further there is book that specifies the amount of labor hours a specific task (job) should take to complete. If that task is specified at 1 hour and the mechanic does it in less time, in theory he can make additional money the more "jobs" he can complete. Regardless of how long it takes the mechanic the customer is billed the labor hours specified in the book plus parts and shop supplies. In addition most dealers charge about an hours labor (about $100) for diagnostics. In some cases the dealer will waive the diagnostic fee if they do the work. In general the shop labor rate locally varies from $85/hr to $110/hr. Independent shops usually have a lower shop rate than the dealers, but not always.
  19. KrisW
    KrisW Active Member
    Jan 8, 2015
    1,194
    2,064
    So the warranty mechanic is incentivised to spend as little time on the vehicle as possible. ouch.
    chrisg05 and Prabhjot like this.
  20. valiant67
    31,994
    11,565
    Not just the warranty mechanic. Any repair.
    UN4GTBL likes this.
