AF: alternator choices? | Allpar Forums
alternator choices?
Discussion in 'Minivans · Pacifica' started by thedriver, Dec 28, 2014.
  1. thedriver
    thedriver Active Member
    Feb 10, 2006
    256
    16
    I think my alternator is going out as my lights flicker while driving-do I have to replace a 105 amp with another 105 amp or can I upgrade to the optional 140 amp?
  2. valiant67
    valiant67 ...
    36,699
    19,477
    I've replaced the alternator with the higher output ones in a couple of my Chrysler cars but never in a minivan just because the vans already had the larger one.
  3. tomit
    tomit Well-Known Member
    Apr 16, 2004
    277
    163
    If the alternator is a Denso, it may be the brush, which is replaceable.
  4. Rick Anderson
    May 28, 2002
    5,412
    2,042
    What lights are flickering? Cause flickering lights can have all sort of causes, and the most likely cause will be different as well.
    If you're alternator is bad, it will light the "Electric System" Warning light on the Dash (the light that looks like a car battery). Either charging system volts to high or low, or the PCM recognizing something obvious wrong with the field control will cause this light to go off. Which a bad alternator will definitely cause this, but less likely, but still possible, a really screwed up battery or a really bad short, and even a simple broken wire to the field control on the alternator.
    Of course, at that point, your bad alternator might leave stranded if its at night and you have to have your head lamps on, you may only have 20 minutes to get to a safe spot before the engine dies; maybe less depending on the shape of your battery.
    What I'm getting at, definitely troubleshoot your flickering lights, just don't jump to conclusions that you have a bad alternator. I have had OEM Denso Alternators last more than 250k miles on 4 Chrysler vehicles I've owned. The rebuilt Denso from NAPA that I replaced on my '95 Cherokee, only lasted 40k miles (the bearings went).
  5. Bob Lincoln
    Jul 10, 2002
    31,904
    5,224
    If it's headlights, make sure the flickering is not actually loose headlamp assemblies that are vibrating slightly up and down. I've seen where that can fool you into thinking that they are flickering, when the brightness is steady, but the micromotion makes you think they are flickering.
  6. John Wood
    John Wood Allpar Legacy
    Nov 13, 2002
    11,096
    166
    It is best to diagnose this rather than shotgun replace the alternator. Simply a loose connection or dirty battery connector could cause flicker. You might have a corroded ground wire... or even a loose connector at the alternator itself.
    Generally speaking, a fully charged battery with solid connections to the cable and ground will absorb or minimize flickering. If the battery is discharged (or bad) than the flickering could be the alternator. I recall having a battery that almost totally failed, and my odometer display flickered from normal to dim in cyclic pattern. The alternator was fine but the battery was faulty. That is why it is best to diagnose the problem. Many autoparts stores will do battery/alternator testing on the vehicle for no cost.
  7. gusc
    gusc Member
    Dec 8, 2004
    517
    39
    What vehicle?
    G4 vans come with 140/160 amp alt.
  8. thedriver
    Feb 10, 2006
    256
    16
    2006 chrysler town and country. the flickering is in all the vehicle lights, not just the headlamps. the battery is less than a year old, but I will check the connections.
  9. gusc
    gusc Member
    Dec 8, 2004
    517
    39
    Do the lights flicker with the engine off? Try this while rocking and bouncing the van. Even better, on a bumpy/rough road for a short distance if it can be done safely.
    My guess is a loose or corroded batt/ground connection.
  10. thedriver
    Feb 10, 2006
    256
    16
    Finally confirmation the problem is in the alternator, the flickering or low power goes away when I tap on it. So, when replacing the 140 AMP do I need to stay with another one, or can I upgrade to 160 AMP? Can I tell the difference visually between them? (I am going to the pick n pull)
  11. gusc
    gusc Member
    Dec 8, 2004
    517
    39
    I doubt any TC ever came with the 140 amp so 160 is your best bet. Even my modestly equipped '03 GC has a 160. My '06 C has a 140.
    They look the same to me, I think the only difference is internal - windings or something like that.
  12. ka9yhd
    ka9yhd Well-Known Member
    Aug 17, 2013
    1,322
    275
    I have seen batteries last 1 year all the way to 10 years.
    When your replacing the alternator make sure all connections are clean. Including the bolts to the brackets which is the ground connection to the engine block.
  13. thedriver
    Feb 10, 2006
    256
    16
    alternator has been replaced, problems are solved. one tidbit tho, all the directions I found said to remove the dipstick tube and roll the things out that way, it is much easier to remove the EGR valve and come straight up.
  14. ka9yhd
    Aug 17, 2013
    1,322
    275
    Glad to hear you got it fixed.
    I have seen some vehicles where after you remove all of the bolts and wires you need to roll the alternator around until you can get it out. Then remember the position you had the alternator in to put it back in.
  15. gusc
    gusc Member
    Dec 8, 2004
    517
    39
    I've had the same batt experiences, had two last 10 yrs and quite a few last 6-7. Some just make it to the warranty year though!
