AF: AN: Cherokee back in limbo | Page 4 | Allpar Forums
Discussion in 'Mopar / FCA News' started by unclejjg, Sep 23, 2013.
Thread Status:
Not open for further replies.
  1. valiant67
    valiant67 ...
    36,699
    19,477
    I suspect they were exagerating a bit, but the software can allow OD to engage at lower speeds or RPMs. The Allpar page lists 9th gear as 0.48 which is more of an overdrive ratio than the 0.67 8th gear of the RWD transmission. But the LX cars using the 8 speed tend to have a lower (numerically) gear ratio so the actual ratio (axle ratio times OD ratio) isn't as great a spread as it feels at first glance.
  2. JoshMHam
    JoshMHam Member
    May 8, 2012
    435
    152
    If it never shifted into 9th, it has nothing to do with how low the ratio is. The shifting program just wasn't meeting the proper criteria to shift into 9th. If it would shift into 9th, then quickly back to 8th (due to lack of power in 9th) then it would be a ratio issue.
  3. MoparNorm
    MoparNorm Active Jeeper
    Aug 2, 2008
    31,138
    7,674
    You change the shift parameters and shift points, by reprogramming the rpm's at which the trans shifts.
    You can have a physical gear ratio, yet fool the computer into thinking its a different ratio.
    Granted that may skew other parameters, so whether it's simple or not, is yet to be seen.
    I know that by resetting the computer on Wranglers, to accommodate tire size and gear changes, an rpm difference of as little as 100 rpm can really change shift points and mess up the overdrive and fuel economy.
    Not to mention performance.
  4. Bob Lincoln
    Jul 10, 2002
    31,904
    5,224
    Ah, but the hand crank could fail to disengage when the engine started, and MANY broken arms were a result of this.
  5. MoparDanno
    Nov 26, 2010
    4,262
    4,629
    Pure speculation here, as I have no inside info on this subject... but please bear with the thought process.
    We have seen Marchionne mess with production schedules and product launches before to suit his "large picture". Is perhaps this Cherokee "delay" merely a way to fire another shot across the VEBA bow and seriously threaten the value of a potential IPO? What better way to give the image of troubles to the outside world ( IE Investors ) than to continually delay a much needed product. With over 17,000 built ( accoring to Oh2o ), I am finding it harder to believe that this delay has anything to do with programming. Just think of the man hours needed to flash those 17,000+ and growing vehicles! Figure 30 mins each, thats 8500 man hours at CURRENT inventory levels.
    IMO, this is totally and completely IPO and VEBA manipulation.....
    Edit to add: I was and am aware of the issues with the 4x4 systems on the Trailhawks, and that could potentially be a secondary thing. But this is not something that would affect the 2wd versions of this vehicle.
  6. Mike V.
    Jan 24, 2008
    26,427
    22,139
    Danno, it may very well be... But reliable sources seem to really be pushing the EPA angle.
    Only time will tell.
  7. MoparDanno
    Nov 26, 2010
    4,262
    4,629
    Quoted for truth!
  8. unclejjg
    unclejjg Member
    Jan 30, 2013
    452
    154
    Tell that to the guy who hosted "Unsolved Mysteries".......
  9. MoparNorm
    Aug 2, 2008
    31,138
    7,674
    It would seem to be multiple issues.
    Overheating and melting components on Trailhawk. (Reported on Allpar several months ago)
    Shifting issues with both the AWD system and FWD system. (Apparently the 9 speed programming)
    Shifting issues with the transaxle/traction control system. (Reported by the JP test driver)
    For the last several months we have heard Chrysler admit issues, without being specific and saying the delay would take a "few weeks", or "two weeks".
    Insiders say EPA.
    The problems could be, one, none, or all, but it is one year behind M's wanted date.
    So far after billions and much turnover, we have Dart and a lot of smoke. Makes me wonder what is really going to happen.
  10. tryphon
    tryphon Well-Known Member
    Nov 27, 2010
    822
    174
    All of which effectively lowers the value of Chrysler...no surprise, really!
  11. MoparNorm
    Aug 2, 2008
    31,138
    7,674
    Ah! The intrigue of Italy!
    Didn't the Pope once "give" Milan to France? ;)
  12. tryphon
    Nov 27, 2010
    822
    174
    To Napoleon (even though it was not the Pope's to give away in the first place...) ...it later went to Austria and then back to the French via the Italian Savoy family. And this is only Chapter 1 of the book!!!!! ;)
  13. Seagondollar
    Seagondollar Active Member
    Jul 28, 2005
    688
    8
    I'm not a Norm fan (nothing personal, Norm), but I gotta give a +1 on this one. If this were a normal (no pun intended) well oiled engineering organization, I'd have to grumble. But these guys are rebuilding the force behind the names that we appreciate. If the whole IPO thing doesn't go south, Chrysler will be moving up in the big 3.
    addicted to dodge likes this.
  14. Longtimejeep
    Longtimejeep Well-Known Member
    Dec 7, 2011
    398
    66
    I hope that's satire. Not much of a future for a company if its' leader would "cut off his nose in spite of his face."
  15. TripleT
    TripleT Allpar Legacy
    Aug 20, 2003
    7,385
    10,193
    Engineering???
    Most are related to programming. I wondering if ZF is helping or not.
  16. tryphon
    Nov 27, 2010
    822
    174
    The owner (FIAT) may decide to capitlize by selling off Chrysler (minus Jeep) and expand into the US by using the Jeep card. As for the satire, etc... I have seen big companies do much worse things: in this case it may hurt Chrysler (with the UAW/VEBA probably seen by FIAT as an ungrateful bunch), but it would ultimately help FIAT, which would gain Jeep and plenty of return on the money they invested in the last three years. Chrysler could be picked up by China and I would love to see the UAW deal with Chinese top management..... (they have already forgotten how things were under Daimler...they sure have short memories...)
  17. hemirunner426
    hemirunner426 Well-Known Member
    Mar 19, 2013
    768
    519
    I agree,i hinted at that earlier in the thread.
  18. Mr.Source
    Jan 22, 2002
    3,779
    2,613
    Chrysler is trying to avoid problems, they will try to fix everything in house before they go to dealers, we have seen in the past that many dealers don't do their job well, so Chrysler will do it.
    Chrysler doesn't want to have the same problems they had in the past with several vehicles, Sergio made it clear, QUALITY before everything, so don't worry, vehicles will be for sale, it doesn't matter if it takes time.
    Just today we were told that customer will be happy to know they will be able to buy one before Christmas !!
  19. hemirunner426
    Mar 19, 2013
    768
    519
    Bingo
  20. Longtimejeep
    Dec 7, 2011
    398
    66
    As has been stated before, VEBA is doing their fiduciary duty for the retirees. Nothing more & certainly, due to their legal obligation, nothing less.
    As for the UAW, they have been very open to the changes since Sergio has taken over.
    As for selling assets, takes me right back to "cutting off your nose in spite of your face."
    Negotiating b.s., nothing more.
Thread Status:
