AF: AN: Wrangler may leave frame, factory, steel behind | Page 45 | Allpar Forums
Discussion in 'Mopar / FCA News' started by Allpar News System, Oct 2, 2014.
Thread Status:
Not open for further replies.
  1. TheMan
    TheMan What color are the clouds in your world?
    Sep 19, 2002
    30,506
    6,002
    Yes....a 1994 Chevy fullsize Blazer (2nd gen) and an AM General M923A1 5ton 6x6 (3rd gen).
    Jackratchett likes this.
  2. unverferth
    unverferth Well-Known Member
    Jun 11, 2003
    2,203
    1,124
    Soooo.....the 'ship has sailed'.....and the next Wrangler will be an aluminum unibody construction, IFS with rear solid axles, fixed winshield, with removable roof panels.........am I close ?
    As I now go run and hide.......
  3. link3721
    Oct 18, 2012
    1,317
    1,148
    Steel frame with aluminum tub highly likely (not unibody), Ram based suspension seems likely, fixed windshield very likely, convertible-ness undetermined, depends on if roof crush test will be required.
  4. TheMan
    Sep 19, 2002
    30,506
    6,002
    Not on the body. Aluminum BOF structure that meets FMVSS216 to eliminate convertible or open body issues.
  5. TheMan
    Sep 19, 2002
    30,506
    6,002
    Now since dave gave the green light to continue....what variants do you want to see?
    ...and lets keep each answer to the types you want to see, NOT a discussion or argument over why or why not of a particular style.
  6. link3721
    Oct 18, 2012
    1,317
    1,148
    Two door, four door, pickup. So keep current two variants plus pickup.
    Moparian likes this.
  7. Moparian
    Moparian Well-Known Member
    May 16, 2012
    4,758
    2,940
    Ill go 1 step further and say 4 door pickup.
  8. TheMan
    Sep 19, 2002
    30,506
    6,002
    Addendum: I will cut this off at 11:00 am to allow me to add up the variants and figure out the changes for each, if possible to include in a single design.
  9. LouJC
    LouJC Active Member
    Oct 7, 2014
    1,045
    881
    Four door and pick up. I would not be be put off by a full metal integrated roof if it was offered, with sun roof option. Once you've been in a 4 door Wrangler you may have a hard time seeing the value of offering a 2 door version.
    Look at what the Japanese makers offer in other markets. The offer a wider range of 4x4 designs than anyone else. I guess the market is not big enough here though or else they would offer those same products here.
    Many people have been clamoring for a Wrangler pick up, esp since the discontinuance of the Dakota. As good as the Ram is, it is just too big for many buyers who have limited parking or have to park in cities. If they offered a Wrangler pick up that WILL be my next Jeep. As it is, I like the latest GC, but it is too car-like and complex to me. I reached my complexity tolerance level with the WK.
    If they use the coil over suspension design on the new Wrangler, a note to those in a position to choose materials: Let's see if you can choose a material for the clevis bolt and lower control arm bushing that does not rust/seize in the bushing on the lower control arm, making a simple shock absorber upgrade a sh!tshow. I can change 4 shocks on a ZJ in less than an hour. These are the things that will push me away from Jeep, if not corrected.
    Let's see if you have the sense to stop using the stupid lug nuts with the tin covers that twist off. Or the cheap plastic clips/retainers that are part of an 'assembly'......
  10. MoparNorm
    MoparNorm Active Jeeper
    Aug 2, 2008
    31,138
    7,673
    Don't want to hijack Bob's thread, but if, as rumored, the Wrangler is getting smaller, a four door variant is probably out of the question. The AEV Brute Double Cab is 24" longer than JKU.
    So don't get your hopes up.
    If any truck variant comes, it is likely to be a jump cab like the Gladiator Concept.
  11. Cornupenuria
    Cornupenuria Well-Known Member
    May 23, 2013
    749
    161
    I was once stationed where there was an RAF detachment on the same base. I got to look at their LRs and saw a larger radius of curvature in many of the body stampings than on our steel-bodied Jeeps and pickups. I then had some understanding of why the LRs were funny-shaped. I visualize Marlin Perkins in a LR being chased by a rhinoceros.
    #891 Cornupenuria, Oct 13, 2014
  12. CDJSalesPro
    CDJSalesPro Allpar Legacy
    Oct 20, 2010
    3,869
    4,345
    whooooooa...... Ok I missed that part..... So are you saying that in addition to possibly not being a convertible Wrangler the 4 door also may not be built?
  13. CherokeeVision
    Dec 9, 2004
    5,919
    2,824
    In the 24 years I have been driving XJ Cherokee's I have never lost one of those covers.
    Of course I do my own brakes and rotation, etc and don't use air tools. So the only time a power tool touches them is when I get new tires.
  14. Cornupenuria
    May 23, 2013
    749
    161
    My M300 motor home had shimmy problems by 25,000 miles while my D300 truck had no problems by its 135,000 mi EOL for rust.
  15. JKU12
    JKU12 Well-Known Member
    Feb 23, 2013
    3,295
    4,094
    I think he meant 4 door truck.
    MoparNorm likes this.
  16. TheMan
    Sep 19, 2002
    30,506
    6,002
    Obvious that you cannot follow simple requests to sit on your hands about comments.....
  17. TheMan
    Sep 19, 2002
    30,506
    6,002
    Obvious you cannot follow simple requests either....
  18. TheMan
    Sep 19, 2002
    30,506
    6,002
    No one said anything about shorter length Norm. You are misinterpreting statements.
  19. kcoc
    kcoc Active Member
    May 8, 2006
    113
    15
    2 door, 4 door and 2 door pickup w/ a small area behind the seats for storage.
  20. TheMan
    Sep 19, 2002
    30,506
    6,002
    Dave....it is also obvious that we are going to have to end these discussions since people cannot sit on their hands again to allow me to continue. Too bad. Like always the few kill the opportunity for the many to learn. Call me and I will answer the questions for your article.
    #900 TheMan, Oct 13, 2014
Thread Status:
