Auto transmission problem
Discussion in 'PT Cruiser' started by Scotland1969, Oct 29, 2017.
  1. ImperialCrown
    18,144
    2,619
  2. Scotland1969
    Scotland1969 New Member
    Oct 29, 2017
    12
    Thank you, I'll take a look at the weekend. It's dark by 4.30 here now!
  3. pt006
    pt006 Active Member
    Dec 24, 2014
    1,269
    478
    Body tag: open the hood, look behind the engine, the firewall/bulkhead is the vertical sheetmetal that goes across the inner fenders. The tag will be on your left under the air conditioning plumbing. A flashlight will help.
  4. Scotland1969
    Oct 29, 2017
    12
    I can't find the body tag anywhere
  5. ImperialCrown
    18,144
    2,619
    From the 2007 service information:
    The Body Code Plate is located in the engine compartment on the plenum behind the right side strut tower . There are seven lines of information on the body code plate. Lines 4, 5, 6, and 7 are not used to define service information. Information reads from left to right, starting with line 3 in the center of the plate to line 1 at the bottom of the plate.
    [​IMG]
  6. Scotland1969
    Oct 29, 2017
    12
    I don't have the plate, only the chassis number stamped into the panel
  7. ImperialCrown
    18,144
    2,619
    Does it even look like the plate was ever there? Possibly the export PT is different?
    P.S. - Check your inbox for a message.
  8. Scotland1969
    Oct 29, 2017
    12
    There's no rivet holes so I guess not
  9. chuzz
    chuzz Well-Known Member
    Apr 3, 2004
    6,789
    461
    Take a photo of the entire firewall and post it. Maybe someone else can spot it, if it's there.
