AF: Axle wants to stick around | Allpar Forums
Discussion in 'LH: Large Cars, 1993-2004' started by movinyou, Mar 28, 2018.
  1. movinyou
    movinyou Active Member
    May 25, 2003
    214
    17
    Hello again all. Trying to replace the L/front axle on my 99 LHS and it doesn't want to break loose. Have tried a slide hammer tool and a few other things to include having my 400 lb son get on it with a pry bar with no effect. Slide hammer gave enough yank to move the engine on impact. But, no hint of the of the C/V joint moving on the stub axle. Am I missing something here?
  2. FIREM
    FIREM Active Member
    Jan 4, 2013
    34
    12
    Brute force does not always work. Have had some come off with a few whacks, others did not want to move. Have had luck by first tapping it back towards the trans, then rotating the axle as "smartly" tapping it. Just keep rotating and tapping. "Smartly" tapping is less than a whack but more than a gentle tap. The trick is to get the circlip to compress and allow the hub to slide off. There is also an o'ring at the circlip that needs to be convinced to let the circlip compress.
    Worst case have had to grind and split one or two to get them off.
  3. movinyou
    May 25, 2003
    214
    17
    Thanks for the comeback. I suspected I might have to cut this buzzard off. Thankfully I bought a new axle so, no core charges. I am just worried about doing damage to the stub axle and tranny internals with all the yanking and banging. And, does anybody know where to get a new circlip if the old one gets damaged? A new shaft from AZ doesn't come with one
  4. FIREM
    FIREM Active Member
    Jan 4, 2013
    34
    12
    Dealer item recommended. Aftermarket not so much. Should replace both, have seen an axle or two slip off the stub just enough to have vehicle not move
    4593012 Circlip
    6502363 Oring
  5. ImperialCrown
    ImperialCrown Moderator
    21,188
    4,387
    A short, hard rap or jerk breaks them loose easier than a steady, applied prying force. You want to 'shock' it loose.
  6. movinyou
    May 25, 2003
    214
    17
    I tried it with a slide hammer and a "fork" type attachment with no luck. any other suggestions?
  7. ImperialCrown
    21,188
    4,387
    Air hammer directed at pushing the inner joint housing outward?
  8. Tomguy
    Tomguy Well-Known Member
    Oct 4, 2011
    1,237
    934
    What works for some may not work for others, but I applied a small constant force with my 4 foot breaker bar (maybe 5 lbs), then smacked the end of it with the sledge a couple times. That was the only thing that worked for me.
  9. movinyou
    May 25, 2003
    214
    17
    Anything is worth a try!
  10. movinyou
    May 25, 2003
    214
    17
    Gonna try it again tomorrow. With all the suggestions, 1 of them ought to work
  11. movinyou
    May 25, 2003
    214
    17
    Ended up starting to cut off the collar with a dremmel. Gonna make a couple of cuts, try and spread it a bit and see what happens.
  12. movinyou
    May 25, 2003
    214
    17
    Got part of the inner C/V joint color to break loose only to find the spline shaft covered in rust. Guess the shafts are the originals. Seems that along the way, Chrysler discovered the same problem and did a slight redesign on the collar of the inner joint making room for the now required "o" ring that I happened to find at a dealer in KC. I bought the 3 they had. Gonna finish cutting the rest of the collar off tonight. Thank God for dremmels!
  13. movinyou
    May 25, 2003
    214
    17
    Folks, this is what it took to get this sucker out, about a dozen dremmel blades, and an air punch
    ImperialCrown likes this.
