Ball joint removal
Discussion in '200, Avenger/Sebring, Cirrus/Stratus/Breeze' started by Ifixjetz, Jul 28, 2017.
  1. Ifixjetz
    Ifixjetz New Member
    Jul 28, 2017
    3
    I need to replace a rear upper ball joint on my 2002 sebring vert. I replaced the other side with a press from autozone, but i was wondering if there is a different adapter i should be using to press this out. Looking for a way to press this out rather than using the ball joint shaft to press it out and have it push thru the top.
