Battery Removal for 2008 Sebring
Discussion in '200, Avenger/Sebring, Cirrus/Stratus/Breeze' started by saltydog, Jan 5, 2013.
  1. ImperialCrown
    18,326
    2,697
    There are some advantages to keeping the battery out of the engine compartment.
    One is the battery-killing heat. The ThermoguardĀ® battery cover kept fresh air blowing on the battery to keep it cool. An insulating blanket came on OEM batteries to shield them. Many of these didn't fit a new battery and/or weren't transferred over to the new battery and go missing.
    The cab-forward design didn't give much topside room under the hood. The LX cars and some others have the battery in the trunk. Jumper cable connections are provided under the hood.
    Lowering the battery also lowers the vehicle's center of gravity. Batteries are a significantly heavy component.
    For jump starting, it is safer to connect to the +/- studs with the battery out of the way as batteries can emit explosive gases and have injured people. I had one pop the caps and spray me once when hooking up jumpers made a spark.
    As far as easy-to-get-to? All modern batteries are Maintenance-Free. Of course they are out-of-sight, out-of-mind and battery terminals are rarely cleaned or serviced, but they figure that a battery may only need attention about every 5-7 years. Most can be changed in 10-15 minutes anyways.
    saltydog likes this.
  2. saltydog
    saltydog Well-Known Member
    Mar 26, 2010
    2,207
    336
    I have to agree with IC, I have owned several J car's and battery replacement is not needed very often, so its location is fine.
    With the 2008, the battery needed replacement sooner than most, due to the electronics's(NAV and convertible top motor's) draw on it.
    My mother n Laws 2007 Sebring is still on the original battery.(knocking on wood right now)
  3. geraldg
    Ad-Free Member
    Nov 28, 2002
    3,819
    744
    I guess most of you people do not realize that in AZ you replace a battery every 2 to 3 years, so when you say 7 to 8 it doesn't apply here.
    wolfsblood07 likes this.
  4. Mopartial
    Mopartial Fits and Finishes
    Mar 6, 2012
    1,098
    859
    I had a '96 Stratus and you're right about the "tad more access" by turning the wheel. The tire needed to come off as well. though. It was inconvenient, but tolerable as batteries do not need servicing and replacing as often as in the past.
  5. Mopartial
    Mar 6, 2012
    1,098
    859
    I certainly did not know that. Interesting. Thanks for sharing.
  6. Bob Lincoln
    Jul 10, 2002
    29,939
    3,325
    Here in the Northeast, it will be a problem with corrosion in removing the battery hold-down and bracket. It's a struggle underhood, will be worse down below.
  7. Doug D
    Doug D Virginia Gentleman
    Aug 10, 2000
    12,212
    1,708
    Yep. I recently had to clean the battery terminals on our Journey. Was having some starting issues and upon checking I had noted the voltage was lower than normal - 12.3 at rest and only 13.3 with the enigne running. After cleaning voltage was 12.5 and 14.3 respectively. Accessing the battery was a major pain. Had to jack up the LF, remove tire and then remove the panel to access the battery. Not much room to work with.
    Battery posts had slight film build up. Cleaned the posts and connectors with a wire brush and put it all back together. Will gladly pay someone to replace the battery when it needs replacement.
  8. saltydog
    Mar 26, 2010
    2,207
    336
    Interesting, the extreme heat?
    I live in central CA and we have some long hot summers, but I am guessing it's not like AZ
  9. saltydog
    Mar 26, 2010
    2,207
    336
    Yea that could be a issue, I would some sort I'd rust inhibitor to slow the corrosion.
  10. wolfsblood07
    wolfsblood07 Active Member
    Mar 26, 2017
    131
    116
    I have gotten over 3 and a half years of service from the battery in my 2014 Avenger. That's pretty good for Phoenix.
    It will need to be replaced soon. We'll see if Walmart balks at replacing it.
